Activity Forums Adobe Premiere Pro timeline mpeg playback is jerky
  • timeline mpeg playback is jerky
    Posted by Rperez1972 on November 25, 2006 at 6:47 am
    I am editing mpeg video but am getting mostly jerky playback not synched with sound, etc…
    its difficult to work with at the least, but when exported it seems to be fine.
    anyone know why this is occurring? and fixes?
    sysinfo
    Adobe PP 1.5.1
    1GB RAM
    3.0 GHz Intel
    thanks,
    richard
    William Schutz replied 19 years, 10 months ago 5 Members · 4 Replies
  • Tcindie
    November 25, 2006 at 8:43 am
    Probably because premiere prefers frame accurate video, and mpeg relies on keyframes to keep things in sync. You’d probably do well to convert your mpeg to either DV or uncompressed format before editing it.
  • Mike Velte
    November 25, 2006 at 12:07 pm
    You will have better luck with Premiere Elements 3.0 and editing files other than DV.
  • Alex Jusay
    November 26, 2006 at 8:34 am
    You need to get the mainconcept mpeg pro plugin if you want a decent editing experience with Mpeg on premiere pro.
  • William Schutz
    November 27, 2006 at 11:21 pm
    Does it do it when you play back an AVI or Quicktime it might be premiere is sampling the wrong field i am using on older version of premiere the way i fix that problem i Open the Capture window then clos it that usally fixes the problem.
