Activity › Forums › Adobe Premiere Pro › Timeline looping, how to switch off!
Walter Biscardi
July 10, 2013 at 6:45 pm[Steve Connor] “I haven’t had this work correctly on 4 different systems since 5.5”
Ok, that’s weird. We edited almost 12 months with CS6 before switching to CC and we did not have that problem. If we did it would have driven us insane. No clue what to tell you. We have 7 total installs for the company, none of them exhibit this.
Walter Biscardi, Jr.
Editor, Colorist, Director, Writer, Consultant, Author, Chef.
HD Post and Production
Biscardi Creative MediaFoul Water Fiery Serpent, an original documentary featuring Sigourney Weaver. US & European distribution by American Public Television
MTWD Entertainment – Developing original content for all media.
“This American Land” – our new PBS Series.
“Science Nation” – Three years and counting of Science for the People. -
Steve Connor
July 11, 2013 at 10:44 am[Steve Connor] “[walter biscardi] “We have two systems that have been cutting with CC here for some time now, both iMacs, and playback behavior is correct. When looping is off, Playback stops. When looping is on, playback loops.
Same with my home iMac system. I’m not seeing the software get “stuck” in looping.
”I haven’t had this work correctly on 4 different systems since 5.5″
Just re-installed Premiere CC and it’s finally stopped looping!
Steve Connor
There’s nothing we can’t argue about on the FCPX COW Forum
Gem Young
August 27, 2013 at 11:33 amHi,
This will stop your sequence timeline looping….
In the timeline. Top right pull down arrow. Untick “Work area bar”.
Best
Gem
Houston Wells
November 8, 2013 at 5:37 pmPP CS6 same issue as described… and a fix (not a workaround).
In the program monitor, I checked the settings dropdown menu (the wrench icon), and “loop” was unchecked. I tried turning it on and off, both settings continued to loop the sequence when the final frame was reached.
I then went into my “buttons editor” (the plus icon at the base of the program monitor), and dragged a “loop” button onto my visible buttons palette. Switching this on and then off did the trick. Now, no looping in that sequence.
Hope this helps.
Houston
Peter Berdovsky
March 8, 2014 at 8:23 pmThat’s brilliant Houston!
Thanks so much for this discovery! It’s been driving me bananas. -
Hank Friedmann
September 15, 2014 at 2:05 amoh man, guys, final cut was great, but it’s dead. now we’ve gotta stop using that space bar. turn looping off and only use “J” “K” and “L”.
we did it! where’s my parade?
David Arshadi
October 10, 2014 at 10:44 amGo to preferences and in General untick the box that says “A playback end, return to beginning when restarting playback”
That should turn off the auto looping
David Arshadi
Editor -
Jay Rozanski
March 25, 2015 at 2:53 pmThanks Houston Wells (on Nov 8, 2013)
Adding/dragging the loop icon to palette then switch on and off worked for me too…
Jay
Jay Rozanski
March 25, 2015 at 2:55 pmThanks David
Changing the default option within Prefs/General has worked.
Jay
