Activity Forums Apple Final Cut Pro Legacy TIMELINE IS NOT PLAYING WELL
  • TIMELINE IS NOT PLAYING WELL
    Posted by Mark Chadwick on September 26, 2005 at 11:14 pm
    Hello everyone,
    We have a project that contains large pict files. Our framesize is 1600×1200 (square pixels).
    We found out last year through trial and error that FCP couldn’t take files larger than 50inches X 50inches. We are zooming in and out and spinning some of these
    picts that are 50×50 or smaller. When we play the timeline it gets hung up on some of the pict files and it seems like its after a dissolve. Is there a way to speed up
    or make the timeline play without any hickups? I’ve already increased the memory usage in final cut pro to 100%. What should the cache be?
    Any suggesions would be great.
    G5 dual 2gig/ 1.5gig of ram
    xserve tower
    mac osX 10.3.9
    decklink HD pro
    thanks
    mark
    Debe replied 20 years, 12 months ago 3 Members · 5 Replies
  • Debe
    September 27, 2005 at 3:51 am
    I’d start with more RAM.
    How many MB are these PICTs, and how many do you have strung together in a row? Compare that to how much RAM you have, knowing the FCP likes a whole gig to itself under “normal” circumstances. You are then adding these huge files…and the OS needs some of that RAM…
    Not knowing how large your PICT file sizes are, it’s tough to know if I’m barking up the wrong tree or not…
    debe
  • Debe
    September 27, 2005 at 4:06 am
    Oh, and in the meantime, you could try trashing your FCP preferences and repairing your OS permissions.
    Repairing permissions is done in Disk Utility usually located in [main hard drive]>Applications>Utilities.
    For info on trashing prefs, look at this site…
    https://www.lafcpug.org/trashing_fcp_prefs.html
    The following is a nifty little program that stores and trashes prefs for you. Just be careful backing up the first time. Make sure you’re backing up clean prefs.
    https://fcprescue.andersholck.com/
    debe
  • Thaxter Clavemarlton
    September 27, 2005 at 12:31 pm
    It goes without saying (so I’m TYPING IT) that you need to FULLY RENDER everything on this timeline.
    And…
    There is a function in FCP that is often overlooked… and it can help with many audio and video “skipping”, “sticking” and “missing” problems.
    You should “Mixdown” the Audio for playback before you dub out of FCP, or during the edit, if you have audio/video stuttering, drop-outs or freezes.
    NOTE: Mixdown has even been demonstrated to help with slipping, skipping problems (or “missing” audio clips) for files being EXPORTED as QT (or similar) files out of FCP.
    First, SELECT ALL of your audio tracks (highlight them) on the timeline, then:
    Sequence Menu > Render Only > Mixdown.
    You should see a dialog box telling you its rendering.
    It might seem to make little sense that “Mixing down” even simple audio tracks will “fix” complex video “freezes” or random audio dropouts to tape or export, but it CAN.
    NOTE: It does not matter of you only have one audio track, if there are random freezes during output, you should try the Mixdown.
  • Mark Chadwick
    September 27, 2005 at 11:34 pm
    hello,
    Its a complex project. The files are around 1.5 all the way up to 40mb. The show will consist of around 75% of picture content. Reducing the size of the picts is something we don’t want to do because it is going to be
    shown on a globe projection screen 1600×1200. The G5 has about 1.5gig of ram. You think I should up the ram?
    thanks for your help everyone.
    mark
  • Debe
    September 29, 2005 at 3:57 pm
    Yes, I really think upping the RAM will help. At least to 2 gigs for FCP alone, 3 GB or 4 GB if you plan on having Motion, LiveType, Soundtrack and/or Photoshop open at the same time.
    If you can keep the photos to only as large as they need to be to accomplish your effects, that will help as well.
    And play around with the different playback options in the Render Control tab of the Sequence Settings. Until you have your timings set, you’ll save a lot of time rendering in a lower resolution.
    debe
