Activity Forums Apple Final Cut Pro Legacy Timeline holding last frame of clip
  • Timeline holding last frame of clip
    Posted by Dean Mikulla on April 1, 2006 at 4:47 pm
    When I’m adding clips to the timeline, sometimes I’ll get to a point where the second to last clip’s frame holds as the timeline continues on through the next clip I added. I’ve tried shaving off (trimming the frame out), thinking it’s a dropped frame, (I had the report dropped frames box unchecked). But the remianing last frame just holds, no matter how much I trim the clip back.
    1. Whats happening here?
    2. When I get a dropped frame error message, can i salvage that clip somehow, and make it work?
    thanks, Dean
    Powerbook G4
    Gdrive Q
    FCEHD
    Dean Mikulla replied 20 years, 5 months ago 2 Members · 2 Replies
  • Tom Meegan
    April 2, 2006 at 5:05 am
    Just to clarify is this problem only on one clip? Different frames but the same clip?
    I had a very similar problem. I didn’t hunt down the cause because I was working under deadline. A reboot did not help, so I re-captured. It was OK after a re-capture.
    If it is happening to lots of different clips, this is not the answer. In that case you should provide as much detail about your system as you can.
    Tom
  • Dean Mikulla
    April 2, 2006 at 1:33 pm
    Its only on certain clips, if I dont use the clip, I dont have the problem. I havent tried recapturing but that sounds like the problem.
    I’m using a Sony TRV 140 , just an inexpensive dv cam.
    I’m just learning so I think I need to read up on dropped frames , why they happen.
    Thanks again.
