Activity › Forums › Apple Final Cut Pro › Timeline goes out of order when exporting as h.264
  • Timeline goes out of order when exporting as h.264
    Posted by Eliza Strao, on March 21, 2012 at 6:36 pm
    I am working with a one minute clip with photographs and an audio overlay. When I export using h.264 the timeline gets out of order. When I export using “current settings” this does not happen.
    What can I do to fix this?
    Jerry Hofmann replied 14 years, 6 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    March 21, 2012 at 8:37 pm
    What is the source material’s orginal format? H.264? or?
    If you export a movie file that’s using ProRes as it’s codec (Share/Export Media…) – It’s likely your sequence is ProRes already) I’ll bet that file will work by just opening it in compressor and compressing it to h.264 independently of FCP.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
