Activity › Forums › Apple Final Cut Pro Legacy › Timeline Frame Rate question??
Posted by James Dow on June 6, 2014 at 2:32 amI screwed up and shot some interviews on my HVX200with the record setting at 1080 30p. My b-roll will all be at 23.98 fps. I’m on FCP 6.7…what is the best way to make this work?
JPDJPD
James Dow replied 12 years, 3 months ago 3 Members · 5 Replies -
Shane Ross
June 6, 2014 at 2:36 pmThe best way would be to use After Effects convert the footage to 23.98 and interpret the footage in a magical way. Sorry, not sure what that way is, I know an AE guy that converted 30p to 24p for me smoothly.
With the tools you have, the best way is with Compressor, and all the frame controls set to best. Even then, there will be some stutter. It’s easier to go 23.98 to 29.97 interlaced….then 24p to 30p…or 30p to 24p.
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
James Dow
June 6, 2014 at 10:53 pmThanks Shane. I think I figured out a work around. I dumped the 24p bRoll into Premiere and spit out 30P source clip…it doesn’t look too bad. Guess I just need to make the jump to Premiere. By the way, your posts have helped me numerous times. You Da Man!
Thanks so much,
JPDJPD
James Dow
June 6, 2014 at 11:00 pmNo specified deliverable frame rate. It’s for an internal corporate function, then their website. Think I have a plan…used Premiere to convert 24p to 30p…looks Ok.
Thanks for your response.
JPD
Nick Meyers
June 8, 2014 at 12:16 amor simply “conform” all the b-roll to 30fps using CInema Tools
it’ll run a tiny bit slow, but for b-roll it might not be important.
the up side it doing the conform is instantaneous.nick
James Dow
June 10, 2014 at 9:41 pmThank you for the suggestion. I’ve never used Cinema Tools…might have to try that.
JPDJPD
