Activity › Forums › Adobe Premiere Pro › Timeline fault
Timeline fault
Posted by Monica Bernabe on June 26, 2011 at 4:21 pmHi!
I am perplexed by a problem that surfaced immediately after I had a replacement hard disc installed on my laptop. All programmes, including APP, were reinstalled and have been running fine, except for one thing when I am editing on APP.
When I have chosen in and out points on a clip in the viewer and then drag it into the timeline, it appears magnified by around 30-40 per cent, with the obvious loss of video quality.
I have no idea why it does this…it never did before the hard drive replacement. I have searched settings and come up with no solution…anyone got any ideas that could help?
Many thanks
MonicaJeff Greenberg replied 15 years, 3 months ago 4 Members · 7 Replies -
Chris Knight
June 26, 2011 at 5:13 pmCouple of options…
Are you sure the footage matches the sequence settings? Try dragging a clip onto the “New Item” icon (bottom of Project Window).
Additionally, check the preferences to make sure Premiere isn’t automatically scaling clips to the sequence size (Preferences – > General – > about half way down there’s a checkbox next to the sentence “Default scale to frame size.” This should be unchecked.
Lastly, since this is a newly restored system, your video drivers could be older, causing video redraw issues. I would suggest updating them.
Ann Bens
June 26, 2011 at 5:31 pmIs the Program Window set to ‘fit’ if all the other above options do not give any results.
Jeff Greenberg
June 26, 2011 at 11:50 pmYou don’t say what version of Premiere Pro you’re using – what you’re describing sounds like a mismatch between your footage and your timeline.
In V.5 you drag a clip to the new document icon (on the bottom of the browser panel, in v 5.5 you can right click and say new sequence from clip.
Let us know how that helps or not.
Best,
Jeff G
Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
You should follow me (filmgeek) on twitter. I promise to be nice.
Come See me speak at NAB!
Compressor Essentials from Lynda.com
(older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
Contact me through my Website -
Monica Bernabe
June 27, 2011 at 8:26 pmyep…when I alter that mode, it reduces or expands the exact same image. I´m beginning to think there´s a deeper glitch 🙁
Monica Bernabe
June 27, 2011 at 8:31 pmHi, the version i have (2.0) is old, too old I guess for the new item suggestion. That didn´t work. The default option in the preference settings was already unchecked. Time for a new version, I think! many thanks for your suggestions…if you know of any others…?? best M
Monica Bernabe
June 27, 2011 at 8:32 pmHi Jeff,
Thanks a lot for the advice. The version is 2.0. I have tried dragging a clip into the New Item tab in the bottom of the screen, I guess to set the sequence settings (?), but nothing happens which I think is because the programme is old. I will probably buy a new version as it´s time to upgrade anyway and that should give me the flexibility to make my own settings. Unless there´s anything else to try??
all the best! -
Jeff Greenberg
June 27, 2011 at 8:36 pmThat started in V.5.
In V.2 (which I don’t have anymore) You need to know what kind of footage you have….so we can tell you what kind of sequence to create. V5.5. (current) works a whole tons better. 😀
Best,
Jeff G
New- my book (with Richard Harrington and Robbie Carman)- An Editor’s Guide to Adobe Premiere Pro
