Activity › Forums › Maxon Cinema 4D › timeline editing keyframes of selected item only
  • timeline editing keyframes of selected item only
    Posted by Alan Langdon on May 18, 2010 at 12:38 am
    2 questions:
    I am doing an animation with lots of objects and I would like to have the timeline window automatically ONLY display the object I have selected. This way I can edit it’s keyframes quickly, slide them back and forth, etc. I would like to select an object and have the timeline automatically show that objects F-tracks, for example.
    Another one is that I have the simplified timeline below my 4 views which only shows a time ruler and the object’s keyframes as yellow marker. When I select one of those keyframes and try to drag it back and forth in time, all the other keyframes come together, as if locked in time together. I want to quickly adjust the distance between keyframes. (My more detailed timeline window is on another screen.)
    Thank you!
    Alan Langdon replied 16 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
