Activity › Forums › Maxon Cinema 4D › Timeline convert 25fps – 29.97fps/30fps ?
  • Timeline convert 25fps – 29.97fps/30fps ?
    Posted by Andy Stokes on September 6, 2006 at 8:06 am
    Hi all,
    I’ve produced some 3D sequences at standard PAL 25fps. I have now been asked to make NTSC versions of these elements for Korea/Japan. My timeline in Cinema is obviously set to 25fps. I’ve changed the project settings to 30fps and all the keyframes seem to adjust accordingly.
    Now when i bring the sequences into AE i see the comp setting is actually 29.97fps. Is this something to do with drop v.s non-drop frame ? and if so how should I handle this? I have always worked in a PAL environment so any help on rendering for NTSC would be great.
    Sorry for the slightly off-topic.
    Cheers,
    Andy
    Andy Stokes replied 20 years ago 1 Member · 0 Replies
  • 0 Replies
