Activity Forums Apple Final Cut Pro Legacy Timeline Becomes Un-Rendered!?
  • Timeline Becomes Un-Rendered!?
    Posted by Amber Miller on July 20, 2011 at 7:17 am
    I have been having this problem for quite a while.
    I shoot HDV and capture HDV to ProRes 422. My timeline settings are setup for ProRes 422 and 8 bit (best). 1480×1080.
    Often times, I will have just ONE little clip that needs rendered…… it’ll go through the process just fine and when it finishes, that one little clip will be rendered but then a ton of other clips on the timeline become
    UN-RENDERED and it becomes this vicious cycle of getting the entire timeline fully rendered. I don’t get it! And it’s not just one particular project. It happens on pretty much every new one. I’ve tried in and out points. That doesn’t help. I have everything checked marked under the render all/render selection tab as well.
    Any ideas on this? It’s becoming a royal pain. Thanks so much!
    Amber Miller replied 15 years, 2 months ago 2 Members · 2 Replies
  • Jay Fishback
    July 20, 2011 at 4:00 pm
    Do you have the most up to date version of FCP available for you? How frequently has this been happening to you?
  • Amber Miller
    July 21, 2011 at 6:03 am
    I using 6.0.6. (torn b/w upgrading to 7 or X) But, this happens quite often…..
