Activity Forums Adobe Premiere Pro Timelapse Workflow Making Proxy Media
  • Timelapse Workflow Making Proxy Media
    Posted by Jos Van der plas on December 11, 2015 at 10:28 am
    I shoot a lot of timelapses. I like having the original files for the final render, but image sequences are way too heavy to work with in a sequence so I make proxy files.
    I’ve used ProRes a lot but in Windows it’s not great. I can use ffmpeg to encode the images into prores, but it only uses 1 out of my 16 cores.
    Does anybody have a good suggestion on how to use all threads (cores) on my pc to encode (preferably ffmpeg) images to a proxy format?
    Other formats I’ve tried: NDxHD (no multi threads, also limited frame sizes), XDCAM (no multithreads), h.264 (multithreaded but not a great editing format).
    Charles Gervais replied 9 years, 3 months ago 2 Members · 1 Reply
  • Charles Gervais
    June 9, 2017 at 2:09 pm
    Hey, did you ever get a good answer to this? I’m at the same point 🙂
