Activity Forums Adobe Premiere Pro timelapse with JPEG’s into a Premier project
  • timelapse with JPEG’s into a Premier project
    Posted by Neil Christian on May 22, 2014 at 8:44 pm
    Hi I have 4 or 5 image sequences from a GoPro in JPEG’s and would like to import them into Premier Pro as time lapse’s but at the moment they are obviously very high resolution and I was wondering what was the best workflow for downsizing to HD creating the nicest image, they are in 16:9 already.
    Should I creat a sequence with this size them export to HD and then re import into my HD 1080 project or is there abetter way? Any ideas?
    Neil Christian replied 12 years, 4 months ago 2 Members · 4 Replies
  • Steve Brame
    May 23, 2014 at 12:47 am
    For what it’s worth, we import image sequences from a Canon T3i(2592×1728) and a GoPro(3000 x 2250) and edit in a 720P timeline without any problem at all. Plus, we have all of that extra space to reframe shots if necessary. I generally like to edit with the largest number of pixels possible, then do your downsize scaling on export – unless machine specs get in the way.
    Asus P6X58D Premium * Core i7 950 * 24GB RAM * nVidia Quadro 4000 * Windows 7 Premium 64bit * System Drive – WD Caviar Black 500GB * 2nd Drive(Pagefile, Previews) – WD Velociraptor 10K drive 600GB * Media Drive – 2TB RAID0 (4 – WD Caviar Black 500GB drive) * Matrox MX02 Mini * Adobe CC
    “98% of all computer issues can be solved by simply pressing ‘F1’.”
    Steve Brame
    creative illusions Productions
  • Neil Christian
    May 23, 2014 at 7:27 pm
    Ok interesting so I do my corrections in lightroom then import as image sequence into Premier pro, drop into a 1080 time line and then it gets downsized when i export with the compressor. I’m new to Premier Pro, PC is not a problem it can do all of this, you don’t think there’s any difference between Photoshop and premier for reducing a larger format to HD, both will produce roughly the same quality 1080?
  • Steve Brame
    May 23, 2014 at 7:58 pm
    [Neil Christian] “you don’t think there’s any difference between Photoshop and premier for reducing a larger format to HD, both will produce roughly the same quality 1080?”
    To be honest, I wouldn’t have a clue since I’ve not done a side by side comparison – but there’s a very easy way to find out!
    Steve Brame
  • Neil Christian
    May 24, 2014 at 8:52 pm
    I vanished there due to PC problems but your right and i’ll run a test of before nailing a workflow. Will come back and report the results.
