Activity Forums Cinematography Timelapse day to night???
  • Timelapse day to night???
    Posted by Dale Roberts on May 11, 2009 at 12:34 am
    Hi… having an issue shooting a timelapse of a city goin from day to night.
    How can i get the transition to look seemless- without that little exposure adjustment making it look a lilttle “steppy”?
    Do people go auto iris for this?
    Its a tough one as the city is rather backlit by the setting sun… I’m thinking its all a little ambitious and might have to tighten the shot up a bit and lose the nice sunset.
    Thanks in advance…
    Curt Pair replied 17 years, 3 months ago 3 Members · 2 Replies
  • Mark Suszko
    May 11, 2009 at 2:24 pm
    I have shot 24-hour time lapses outdoors with and without auto-iris. Generally I make a choice about how vital the night part is. If it’s not going to be used or used only a little bit, I will lock the iris down on manual for the best average of the day shots, and lose the night stuff past dusk. If I need a lot of the dusk and dawn, then I’ll employ auto-iris and maybe even a notch of gain, counting on the DCC circuitry to keep it from blowing out too badly over teh brightestnpart of the day, but it gets me longer coverage of the dsk and dawn and any deep night stuff with lights in it…
    Depending on your cloud cover and winds, you’re still going to get a little strobing quality as the sun comes in and out. For me what’s worked to help that is to use shorter intervals between grabs, and get the rest of my speed-up effect by changing speed in the timeline. The more frames you have to work with, the more options you have for things like morphs or optical flow, etc.
    You could also run the captured stills thru a batch action in photoshop to apply some filtration that evens them out. Then put them in the timeline.
    A trick I learned from an expert at this: Composite the day version WITH the night version to get a much more dramatic night version with more perceived detail and more control over where it’s seen.
  • Curt Pair
    June 17, 2009 at 3:05 am
    I love time lapse stuff, and I’ve been practicing the art for about 12 years now…
    First off, what kind of camera will you be using? Still, video, HD? This matters alot now…
    I’ve done them with HUGE still frames, and have gotten some great stuff, using “Pocket Wizards” as my intervalometer. When I did TLs with video, I used Beta and Digibeta… since they don’t have intervalometer, I just “rolled” constantly for sometimes HOURS and then used a Quantel Edit Box to make my speed adjustments.
    Now that the NEW HD cameras have built in intervalometers, life is easy! Decide how fast you want/need the time lapse to move. The LONGER the interval between frames, the FASTER the time-lapse will look in the end. For example if you shot clouds at 1 frame every 20 seconds, versus 1 frame every second, the first TL will move MUCH faster. There is a GREAT time-lapse calculator on my friend Doug Jensen’s website! https://vortexmedia.com/TIME.html Doug is SO awesome, he’s taken all of the guess work in the terms of “time” out of it for you… check it out, he has two versions… one is “how long will it take to shoot 10 seconds in 24p a 1 frame every second?” That’s the version I use most… I often dial up his website on my phone and then roll! (I usually need to know how long I have to stand there! 🙂 )
    If clouds are rolling by faster, or people are in the shot, perhaps the longer frame rates won’t look “right…”
    How do you fix that? Well, that’s easy! If you are fortunate enough to have a camera with “frame accumulation” like the ENTIRE XD CAM HD line, by Sony (including the EX cameras!) Dial in the frame accumulation. This is similar to “slow shutter.” What happens is that the camera will “mimic” a longer shutter period, allowing for some “blur” in your shot. This will help SMOOTH out your time-lapse. I use at least 4 frames on EVERYTHING, even my 1 frame every 1 second time lapses!
    None of that was your REAL question… but I thought it was a good primer. The other post had great information. I’ve shot time-lapses all over the board, and tried a little of everything… THESE DAYS, I prefer using auto iris… HOWEVER, I live in Arizona! We have VERY brightly lit days, which means I have to dial in serious Neutral Density filters, often with a mattebox, and NOT just with the camera’s built in filters… As the sun goes down, I pull them out… UNLESS I want the shot to “go to black” kind of thing.
    I’ll agree with the other post that I often COMPOSITE a few shots together to get my “finished” look. So I may shoot my “day” look as one clip… my sunset as three to four clips and my night shot as another… Why? Because I also induce MORE frame accumulation once the sun goes down…
    With a backlit cityscape you’re in for some trial and error. Do you have a few days to try it a few different ways? I’m afraid the auto iris may not work in your situation. If you do try to do this manually… remember a few things in adjusting your iris… 1) make SMALL adjustments! 2) make your adjustments over an extended period of time! (if you’re using an intervalometer, remember your frame rate… 24 frames, 30 frames, etc. equal one second… if you need to OPEN up, say from F4 o 2.8… try to make that “move” over several seconds to help easy the jumpy look; 48, 60 frames, what have you…. think SLOW AND SMOOTH!) 3) If you have that frame accumulation turned on… the iris movement will also be blurred!
    There are several different methods that work for people in these situations, just try a few and see what works for you…
    Curt Pair
    Picture This Productions
    Sony ICE Team
    F900/F800/F350/PDW700/EX1/EX3/D790/D600
    Adobe Premiere Pro CS3 HD/Matrox
    Phoenix, AZ
