Activity Forums Media 100 TimeFX Broken?
  • TimeFX Broken?
    Posted by Jaeson Koszarsky on March 20, 2013 at 4:41 pm
    Any hints on getting TimeFX to work in Media100 Suite 2.1.2?
    I currently trying to reverse a clip, without any luck. It looks ok until the actual render occurs.
    I’ve had difficulties with speed adjustments in TimeFX too.
    Jaeson
    Gregg Michaels replied 13 years, 6 months ago 4 Members · 3 Replies
  • Jim Downey
    March 22, 2013 at 6:45 am
    Hi Jaeson, I haven’t had any problems with M100 v2.1.2 but with my 844X my timeFX would never work – I did have the occasional win by zooming out the timeline before rendering. May help.
  • Michael Slowe
    March 22, 2013 at 10:06 am
    Jaeson, tested my slo-mo in Media 100 2.1.2 with OS 10.8.2 and it worked.
    Michael Slowe
  • Gregg Michaels
    March 22, 2013 at 1:50 pm
    This bug has been around for a couple of years now, and I believe it still exists. (Not sure if it’s the same you’re experiencing) After you create a TimeFx change to a clip, you have to hit apply before rendering. If you just type in a TimeFX speed and then hit render or just move on with the edit without hitting apply, I believe you get a freeze frame of either the beginning or end of the clip when it eventually gets rendered.
    GM
