Activity Forums DaVinci Resolve Timecodes match – clip is way off vs Offline
  • Timecodes match – clip is way off vs Offline
    Posted by Ola Haldor voll on September 19, 2011 at 10:44 am
    Working on a TV-series, ep 3 of 10. The first two episodes went fine, just some conflicts – no big deal, just a bit tedious.
    In ep 3, I’m struggling with big bunch of clips. They’re mostly connected to the correct source media, however they have slipped many frames, seconds and minutes. They are nowhere near matching the offline.
    I’ve opened random clips in QT7, and the timecode of in-point in FCP matches in QT7. When I go to the same timecode in Resolve, it’s nothing alike.
    I checked a few clips and there’s only one TC stream. No AUX TC etc.
    Really, really weird!
    Update
    I’m also having very slow playback rate. Even though the GPU meter in upper left says 25fps and has a green bar, it’s playing like 5fps…
    Margus Voll replied 15 years ago 3 Members · 8 Replies
  • 8 Replies
  • Margus Voll
    September 19, 2011 at 12:43 pm
    how’s the drive speed under a load of material ?
    Margus
    https://iconstudios.eu
  • Margus Voll
    September 19, 2011 at 12:44 pm
    btw what compression in the files?
    Margus
  • Ola Haldor voll
    September 19, 2011 at 4:13 pm
    All media is ProRes 422
    For now I have to use the old fashioned way. Single QT+EDL. Gotta push this job out the doors asap before it’s going to the TV-station.
    The drives are like this:
  • Mike Most
    September 19, 2011 at 4:52 pm
    Is it possible that either the clips are 23.98 and you’re trying to play them at 29.97, or vice versa? By your description, it sounds like a frame rate discrepancy.
  • Ola Haldor voll
    September 19, 2011 at 4:55 pm
    Timeline and source media is 25fps
  • Margus Voll
    September 19, 2011 at 8:36 pm
    I wonder if this 5 MB sec shows current activity or idle ?
    Or if it is some sort multiplier amount ?
    Margus
  • Ola Haldor voll
    September 19, 2011 at 9:10 pm
    It’s an internal RAID. iStat menu is showing each hard drive as single items, not as a RAID for some reason. And that was during load. I was playing video in Resolve.
    I took about three reboots and it went fine. I have no idea what was causing the lag really.
  • Margus Voll
    September 20, 2011 at 4:32 am
    this 40 megs overhead i not sure if it sufficent with sata drives.
    For me it also seems like frame rate is off a bit like in xml or edl there is some hidden option
    for media files.
    I have seen this with audio editing really many times and usually it is just drop frames option in prefs somewhere.
    Margus
