Activity Forums Apple Final Cut Pro Legacy Timecoded Export
  • Timecoded Export
    Posted by Fafounet on September 28, 2005 at 10:55 am
    Hi everybody,
    How to make a timecoded export ?
    Should I use a time code plug-in or is there a way to do it on the recorder ?
    Fafounet
    Shane Ross replied 21 years ago 2 Members · 1 Reply
  • Shane Ross
    September 28, 2005 at 11:02 am
    Typically if I do I timecoded export, I try to use the deck to supply the code. But this is only if the deck is being fed, or follows, the timeline timecode. If it doesn’t, then it’s TC is useless.
    What most people do is add the TC filter (In the video filters>VIDEO folder) and render….render….render…
