Activity › Forums › Apple Final Cut Pro › Timecode won’t show up in Viewer window of single-cam clips
  • Timecode won’t show up in Viewer window of single-cam clips
    Posted by Dennis Widmyer on December 7, 2013 at 10:04 pm
    Having an issue where I’m literally going to have to rebuild my entire film (within 5 reels) and replace all the multi-cam shots with just the angles themselves. Now since FCX doesn’t have a way to flatten multi-cam clips (which boggles my mind), the way I’ll have to do this is going to be nightmarish. Shift F won’t help me, b/c that will just point to the synced-up multicam clip in my Event folder. Instead, I’ll need to go to the single camera (for the angle I need in the timeline) and then, using the timecode, mark my Ins and Outs and reinsert it into the timeline as a single camera clip.
    This is probably going to take me all weekend, and we’re supposed to be doing our conform on Resolve right now. But Resolve won’t show any of the multi-cam clips, and after spending half the day researching this, it seems like this is the one thing it can’t get past.
    So before I start doing this, I need to know how to view the Timecode on single camera clips. I know that it shows it in the main Display counter (center screen). But when I then try to find the timecode within the timeline sequence on the multicam clip, it shows its own timecode for that clips actual place on the project.
    So in short, I need a way to look at the timecode of the actual portion of the inserted multicam clip in my project, so I can then correspond it with the single camera version of that shot from the Events folder.
    Any help would be greatly appreciated. Losing my mind over here.
    Dennis Widmyer replied 12 years, 9 months ago 3 Members · 15 Replies
  • 15 Replies
  • Bret Williams
    December 8, 2013 at 6:17 am
    Cmd+opt+s
    Let’s you skim (and see TC) individual clips in the timeline.
  • Dennis Widmyer
    December 8, 2013 at 5:54 pm
    Yeah, I spent all night emailing with Larry Jordan about this. Doesn’t work for me with my multicam clips. That option shows me the duration of where I am in that individual clip (not the source timecode). Only way I see the actual timecode is if I go to the solo-cam version of that shot, within my events folder, and skin there. Larry was great, and spent many emails with me trying to figure this out. In the end, we both gave up.
    Dennis Widmyer
    http://www.parallacticpictures.com
  • Bret Williams
    December 8, 2013 at 11:55 pm
    This is where I question whether LJ actually has any real working experience with the product. The concept it gave you was the only option. I couldn’t remember if it showed the TC of the clip or the TC of the multicam clip. Sounds like the latter. For those that have actually used multicam for a year or so, this is a known downside of the software. You can’t match frame back to the actual clip. You can’t even open the multicam and have the play head snap to the same place that that the sequence was. So you have to match frame, mark an out, check the duration, use that to find the in point, etc. A mess.
  • Dennis Widmyer
    December 9, 2013 at 12:13 am
    Agreed, there’s so many ways they could make this easier in subsequent updates:
    1. Allow a way to flatten the multicam clips. (similar to breaking apart a compound clip)
    2. Allow a similar tool (like Shift F) that matches the frames to the original clip, but let’s you determine WHICH angle (not just default to the synchronized multicam clip)
    3. Or at least let you see the source time code of the multicam clip in the main display. Right now, it only shows me the source timecode of the single angle versions of the clip.
    Dennis Widmyer
  • Bret Williams
    December 9, 2013 at 12:52 am
    Yep. All should be implemented in the next release if hope.
  • Jeremy Garchow
    December 9, 2013 at 9:35 pm
    You can open the Angle Viewer, change the “Settings” to show the “Timecode” overlay and “Clip Name”, and at least you will be able to see the tc easily and do a search for the clip in the Browser using the clip name.
    It still doesn’t solve the stupid match frame situation.
    Also, as Bret mentioned, clip skimming (command-option-s) shows me clip tc in the timecode display when skimming a clip in the timeline (this is different from skimming the timeline). It doesn’t for you?
    Jeremy
  • Dennis Widmyer
    December 10, 2013 at 5:52 pm
    Yeah, it absolutely doesn’t work for me, and it’s really starting to screw me up. Ive got my co-director in NYC right now (I’m in LA) and he’s working with a colorist at Deluxe. And last night, he was texting me to fill in some gaps where shots that had speed ramping applied were missing. He needed the source timecode for these shots, and here’s how I had to figure out how to give it to him:
    1. Find the multiclip on the timeline.
    2. Turn on skimming. (command-option-s)
    3. Skim over the clip (mouse over the actual clip). Again, for me, this doesn’t show source timecode. It shows where you are in duration of that entire raw shot, with the shot beginning at 0. (my multicam clips are ignoring the source timecode)
    4. So if I skim over the first frame of the multicam clip, and the counter shows me 01:12:04, I know I’m a little more than a minute into that actual shot/take.
    5. Get the clip’s shot / take number. Example: 26B_1.
    6. Find it in the event browser (the solo version of it). So I’m not using Shift +F, because that would find me 26_1_Synchronized_Clip (the multi version)
    7. Go to the raw shot and skim through till I get to 01:14:04 into the clip. Then make my In there.
    Trouble is, I’m not too good with figuring out how to precisely put an In into a clip at a specific time. I think I know how to do it from the timeline, but not from the event browser. So then I run into the headache of, looking at the source timecode on the solo clip (in the event browser) and doing math in my head so I can figure out that, if the source clip starts at 14:05:03:01, I have to add 01:14:04 to that number to figure out my In.
    But then there’s yet ANOTHER added headache. In some clips, sound begins before the picture, so I have about 9 seconds of black before the clapper appears. So I then have to subtract 9 seconds from my math solution.
    In short, it sucks, and trying to pull him the timecode for just one 6 frame clip he needed for the colorist, took about 20 mins.
    I’ve followed all the steps; have all the settings turned on correctly; even had a long email back and forth with Larry Jordan about this: For some reason skimming isn’t showing me the source timecode of multicam clips. Could this be an issue with how they were imported?
    Dennis Widmyer
  • Jeremy Garchow
    December 10, 2013 at 6:16 pm
    [Dennis Widmyer] “3. Skim over the clip (mouse over the actual clip). Again, for me, this doesn’t show source timecode. It shows where you are in duration of that entire raw shot, with the shot beginning at 0. (my multicam clips are ignoring the source timecode)”
    Then this is your problem. When making the mulitcam clips, there’s a “starting timecode” field. If there’s tc, it usually starts with the clip that has the earliest tc and uses that as the tc for the clip. Do all of your clips have tc?
    The timecode overlay does not show tc (you have to open the Angle viewer)?
    [Dennis Widmyer] “6. Find it in the event browser (the solo version of it). So I’m not using Shift +F, because that would find me 26_1_Synchronized_Clip (the multi version)”
    Oh, wait a minute. Yes, if you are using Synchronized clips, then yes the tc is ignored and all clips start from 00:00…
    Jeremy
  • Dennis Widmyer
    December 10, 2013 at 6:19 pm
    Jeremy,
    Yes, this is only a problem with unsynchronized multicam clips. When I go to the unsynchronized version of the clip, I can see the source code.
    All of my multicam clips start at 00:00. And opening a multicam clip in Angle Editor doesn’t solve the issue either.
    Dennis Widmyer
  • Jeremy Garchow
    December 10, 2013 at 6:30 pm
    Yes, Synchronized clips do not borrow original timecode, and it sucks.
