Timecode resets when I split it
Posted by Austin Bauer on June 28, 2020 at 8:39 pmI insert timecodes by making a new layer with a text media. I make the text blank, set duration to “20:00:00.00”, event fx, “Vegas Timecode”, leave settings default.
This used to work fine but now when I make a split, the timecode resets to zero.
Aleksey Tarasov replied 6 years, 2 months ago 5 Members · 8 Replies -
Francois Pénzes
June 29, 2020 at 2:46 amHi Austin
What version of Vegas are you using ? Vegas Pro (?)
Cheers !
PC Win 10 Pro 64-bit 16gb
Ryzen 9 3900X 12 Core 4.60GHz
Radeon RX 5700 XT
Cameras: Canon XF305 + Canon XH-A1 and a bunch of others
Vegas Pro 16, User since Vegas 3.0\’\’When the cutting stops, the editing begins…\’\’
Austin Bauer
June 29, 2020 at 2:47 am17. Upgraded from 16 recently, but I was having the same problem there.
Graham Bernard
June 29, 2020 at 7:07 am[Austin Bauer] “17. Upgraded from 16 recently, but I was having the same problem there.”
Austin I must be misunderstanding you. You’re adding an EVENT FX so when you SPLIT an EVENT it should reset the T/C. I don’t know what you were getting in 16 but when I SPLIT an Event the T/C resets in both 16 and 17.
* Grazie
PC 10 64-bit 64gb * Intel® Core™i9 – 3.3GHz * 40Gb NVIDIA GeForce RTX 2070
Cameras: Canon XF300 + PowerShot SX60HS Bridge -
Francois Pénzes
June 29, 2020 at 11:28 amHi Austin
Could we get a screen print of your layout ? We all have our specific workflow…
Cheers !
Radeon RX 5700 XT
Austin Bauer
June 29, 2020 at 2:17 pmSorry, I don’t know what “T/C” is. I’m not super familiar with the ins and outs of Vegas. But I remember in 16 sometimes when I made the timestamps it wouldn’t reset when I split it and sometimes it would.
As for taking a screenshot of my layout do you just mean a screenshot of the program? Or is there a specific thing I need to capture?
Either way, I have found a workaround. One of my old project files still has a timecode that allows me to split it. So I just copy and paste the event from there now. It looks kinda blurry for some reason and the “frames” part of the counter doesn’t seem to match up. But the seconds, minutes, and hours match so it doesn’t really matter. I’ll just crop the “frames” part out. Thanks anyway, though!
Edward Troxel
June 29, 2020 at 4:59 pm -
Graham Bernard
June 29, 2020 at 5:50 pmT/C = Time Code
* Grazie
