Activity Forums Apple Final Cut Pro Timecode Reader anyone?
  • Timecode Reader anyone?
    Posted by Bruce Wittman on August 8, 2012 at 4:36 pm
    Has any clever person figured out how to use a timecode reader (not timecode generator) within FCPX? Our clients want a timecode window burn of our raw footage, NOT the timecode of the timeline? I have seen the Spanish plug-in, but it does not work with FCPX Version 10.05, as far as I know.
    Many thanks!
    Bruce Wittman
    Executive Producer
    Eagle Video Productions, Inc.
    2201 Woodnell Drive
    Raleigh, NC 27603-5240
    Website: http://www.eaglevideo.com
    Email: bruce@eaglevideo.com
    pho: 919-779-7891
    cel: 919-818-5556
    Chelsea Wagner replied 13 years, 3 months ago 13 Members · 23 Replies
  • 23 Replies
  • Bill Davis
    August 8, 2012 at 6:07 pm
    Not directly “read” it – but you can click on the Project in the Project Library then open the inspector and use the Action Menu – (the wrench icon) to change the starting timecode of your project to match the value of your original.
    That should sync your window burn with the original tape.
    “Before speaking out ask yourself whether your words are true, whether they are respectful and whether they are needed in our civil discussions.”-Justice O’Connor
  • Mark Dobson
    August 8, 2012 at 6:11 pm
    It’s not possible at the moment Bruce.
    If you put ‘timecode’ or ‘source timecode’ in the search box in the forum post index you will be able to read my previous attempt to discover an answer to this very specific problem.
    I resorted to FCP7!
  • Bruce Wittman
    August 8, 2012 at 6:44 pm
    Hey Bill,
    Thanks for your suggestion. In my case, I have 139 shots (Sony XDCAM) that need window timecode.
    Bruce Wittman
    Executive Producer
    2201 Woodnell Drive
    pho: 919-779-7891
    cel: 919-818-5556
  • Bruce Wittman
    August 8, 2012 at 6:45 pm
    I had to do the same thing. It’s a shame when you have to move backward when moving forward…
    Bruce Wittman
    Executive Producer
    2201 Woodnell Drive
    pho: 919-779-7891
    cel: 919-818-5556
  • Leo Hans
    August 8, 2012 at 6:48 pm
    I had a Free Timecode Reader, but sadly It has stopped working since 10.0.4. I don’t know if its a FCPX/Motion bug or a deliberate change in the filter I was using for it, but It doesn’t longer work.
    https://finalcutargentina.blogspot.com.ar/2011/07/timecode-reader-gratuito-para-fcpx.html
    I have reported the problem to Apple, but It still doesn’t work. Perhaps in 10.0.6? I hope.
    Leo Hans
    Editor AVID – Final Cut Pro
    https://www.leohans.com
  • John Moffat
    August 8, 2012 at 7:21 pm
    There is a workaround that might help.
    Copy the RAW files that you want to send to you client into a new event. FCPX will then copy those files at the finder level into a new event folder. Use Compressor to add burnt in timecode to your viewers.
  • Bruce Wittman
    August 8, 2012 at 7:55 pm
    Hey John,
    Not sure what you mean by using Compressor for each of these 139 separate shots with time of day time code. Sony XCAM gives me a BPAV folder, which I un-compress with the Sony XDCAM browser or bring directly into FCPX Event using Archive Camera Footage. Can you explain further?
    Bruce Wittman
    Executive Producer
    2201 Woodnell Drive
    pho: 919-779-7891
    cel: 919-818-5556
  • John Moffat
    August 8, 2012 at 8:35 pm
    Hi Bruce,
    I’ve not used XDCAM or any files direct from a BPAV folder in FCPX yet so this might not work. Or i’m not understanding what you want. However when you import files into FCPX it will copy (at the finder level) the Quicktime files into “Original Media” folder in the event folder. I would use FCPX to create a new Event and move a copy of the 139 files you need into the new Event. At the Finder level a new Event folder will have been created with a copy of the 139 shots in it. Grab those files and stick them through Compressor selecting add BITC from the options.
    You might need to transcode the files to Proxy or ProRes422 first so compressor can read them. I don’t think it can read BPAV folders.
    john
  • Bill Davis
    August 9, 2012 at 12:33 am
    [Bruce Wittman] “Hey Bill,
    Ok.
    I think the central truth is that if you’re planning to use X as an “intermediary” solution and need to read that original timecode in order to coordinated with an outside editor that must reference the original numbers, the “closed” FCP-X system is not going to work well for this.
    If you’re just looking to do window burns for use with clients to coordinate a paper edit – then there’s nothing to stop you from dragging all 139 clips onto a timeline and doing a timecode burn out of that.
    I do that all the time for clients – and it’s fast and easy.
    And you can use the notes to keyword selects from that window burn timeline and use “reveal in event browser” to transfer your ranges back into your Event.
    So in that sense, the “original” timecode becomes inconsequential if (and it’s a BIG if) you can remain in X through your entire edit..
    But I understand that if you must have references to the camera files because more than one editor with different systems need to use your X selects as a general purpose logging database, it’s not as automatic to get that exported at this stage in the X development cycle.
    I’m willing to bet that this will change over time, because at heart it’s a big database, and importing and exporting data is one of the core capabilities of every database.
    But for now, you probably need a different tool.
    Sorry.
  • Tom Brooks
    August 9, 2012 at 12:56 am
    To make “window dubs” of raw clips I control click on a clip in the Event Browser and select “New Compound Clip.” Double-click to open the compound just created. Add more of your original clips if desired. Put the Timecode generator on top of the whole thing. Seems to work for me. I just share the compounds with clients and use the original clips for my edits.
Page 1 of 3
