Activity Forums VEGAS Pro Timecode Question
  • Timecode Question
    Posted by John Power on November 19, 2010 at 3:05 am
    I need to add timecode to a project so the producer can give me direction of what he wants included and not. I have tried adding what i thought would be source code using media fx but noticed it doesn’t match the original tape times etc and starts at 22:26:26:20 instead of about 15 seconds in.
    What am i doing wrong and what are the settings and procedures to do this ?
    I am using movie studio platinum 10 in Pal format if that makes a difference.
    Video for the Web is kool.
    Mike Kujbida replied 15 years, 10 months ago 2 Members · 7 Replies
  • 7 Replies
  • Mike Kujbida
    November 19, 2010 at 3:37 pm
    What camcorder did you use to shoot the footage?
  • John Power
    November 20, 2010 at 12:27 am
    Hi Mike, I used a Canon XL-H1
  • John Power
    November 20, 2010 at 12:32 am
    Also the next few clips from the same tape seem to have the right time-code when I use media-fx …………it is only affecting the first clip which unfortunately contains the main 40 mins of the interview
  • Mike Kujbida
    November 20, 2010 at 1:02 am
    John, I’m in NTSC land but I vaguely recall reading about an issue with PAL and time code if you start capturing from the very beginning of the tape.
    Try letting the tape run for at least 5 seconds before you start capturing and see if that helps.
  • John Power
    November 20, 2010 at 1:27 am
    Thanks Mike, I’ve checked another tape and seems to have the same issue…….I will try your suggestion.
  • John Power
    November 20, 2010 at 2:49 am
    Further to this………..it seems that if I start capture a few seconds in (and don’t use tape capture) all seems to be fine with the time-code ……not sure why, but I can get around it.
  • Mike Kujbida
    November 20, 2010 at 10:39 am
    Glad that it worked for you.
    An even stranger quirk is that, if you don’t do as I suggested, your timecode may end up being NTSC and not PAL.
    Figure that one out.
