Activity Forums Adobe Premiere Pro Timecode Problem from Premiere to Audition
  • Timecode Problem from Premiere to Audition
    Posted by Glenn Tak on August 27, 2014 at 2:32 am
    I exported an Aiff file from Premiere. 23.976. Brought it into Audition. Did some work on it in the waveform editor (not the multitrack) saved it and re-imported to Premiere Pro. The audio is significantly longer and out of sync.
    First… I know there is a way to send Audio over to Audition and round trip it back but it sends all the individual edited clips. I needed to send 1 Audio track that I could clean up.
    Apparently Audition is converting the frame rate… I assume to 29.97. Can’t figure out how to prevent this.
    I tried it with a wav file export from Premiere as well. Same issue.
    Is there a workaround or better workflow I should be looking at?
    TAK
    ______________________
    “Nothing is Easy”
    Jethro Tull
    Alex Udell replied 12 years ago 3 Members · 3 Replies
  • Paul Neumann
    August 28, 2014 at 4:33 pm
    Try not exporting. Just send the clip to Audition.
  • Glenn Tak
    August 28, 2014 at 4:42 pm
    Problem is… it is a heavily edited dialogue piece. If I try to send it to Audition it sends it as separate edited pieces. Almost thirty of them. I need it as one clip so I can clean it and effect it as one.
    An audio mix down function in Premiere would be helpful so I could make one clip, “send” it to Audition and bring it back.
    “Nothing is Easy”
    Jethro Tull
  • Alex Udell
    August 28, 2014 at 8:16 pm
    just some thoughts off the top of my head…
    1) in PPro, is there a way to adjust the frame rate using the “interpret” options available by right clicking the asset in the project panel?
    2) if you send as a multitrack from ppro to audition…you can still bounce the multitrack session in Audition to 1 track…which will result in a new flat file you could then edit…if you prefer to edit that way…
    Alex Udell
    Editing, Motion Graphics, and Visual FX
