Activity Forums Adobe Premiere Pro Timecode plug-in won’t render with CUDA
  • Timecode plug-in won’t render with CUDA
    Posted by Max Chernyaev on July 19, 2016 at 9:50 pm
    I face a strange issue with all my sequences and projects. Timecode plugin doesn’t show up if CUDA is enabled AND you select ANY source track except None.
    Say you need to render two timecodes over one video clip: 1) from V1, 2) V2. You put two plugins and see only the one that’s configured to None source track.
    As soon as you switch to Software only, all plugins show up as expected.
    Same in Media Encoder.
    2015.3
    Mac Pro 2011, Quadro K5000, GTX980Ti, 10.11.5, latest CUDA driver and Nvidia driver.
    Someone having the same issue?
    Max Chernyaev replied 10 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
