Activity Forums AJA Video Systems Timecode out of Kona 3
  • Timecode out of Kona 3
    Posted by Jamie Pickell on August 6, 2010 at 3:31 pm
    I use the Kona 3 Timecode Burn-in option in the control panel and take the composite and analog outs to make a real-time DVD of my sequence. This is fantastic and has saved me tons of time avoiding Compressor. That being said, the TC Burn-in window is quite large and sits right over any lower thirds I have in my show. Does anyone know of a way to move the TC Burn-in window and/or to shrink it? Ideally I would like it to sit just below the letterbox SD output. Any suggestions or help is much appreciated.
    Cheers,
    Jamie
    Dual 3.2 Quad-Core
    8GB RAM
    FCP 7
    Kona 3 with break-out box
    Mark Spano replied 16 years, 1 month ago 3 Members · 3 Replies
  • Aja Sales department
    August 6, 2010 at 5:04 pm
    Jamie,
    The timecode window burn produced via the AJA Control Panel>Timecode tab feature does not offer placement control. We will take this feature request under consideration.
    Happy to hear that the window burn timecode is useful to you.
    AJA Video Systems
    +1 (530) 274-2048 Intl.
    (800) 251-4224 US
    sales@aja.com
  • Jamie Pickell
    August 6, 2010 at 7:01 pm
    Thanks for responding to my post. The TC Burn-in has been a lifesaver. Right now I’m burning out to DVD recorder for a screening an hour from now. If you could add the flexibility of positioning the TC burn-in window, that would be fantastic.
    Thanks again,
    Jamie
  • Mark Spano
    August 9, 2010 at 5:37 pm
    If you are in a pinch, try QT Sync. It has saved me some time. You can load up a Quicktime, add a TC burn-in (with basic placement and size), and export a ref QT with burn in (no render or save time). Load that up into AJA TV and play out – wheee.
