Activity Forums Adobe Premiere Pro Timecode not matching?
  • Vince Becquiot
    March 12, 2015 at 3:06 am
    Hi Ben,
    Is the footage interpreted correctly? You can check the interpret settings by right clicking on the clip in the project panel.
    Vince Becquiot
    Indigo Live | Kaptis Media
    San Francisco Bay Area
  • Ben Allan
    March 12, 2015 at 3:10 am
    Hmm didn’t know about this. What am I looking for? The frame rate is correct?
  • Vince Becquiot
    March 12, 2015 at 3:16 am
    Yes, is it interpreted as 23.976?
    Vince Becquiot
  • Ben Allan
    March 12, 2015 at 3:17 am
    Yes it is :/
  • Vince Becquiot
    March 12, 2015 at 3:26 am
    hmm, it also looks like the difference is close to what a drop frame vs non drop would give you. You might want to look those settings throughout your workflow.
    Vince Becquiot
  • Ben Allan
    March 12, 2015 at 3:33 am
    OK thanks for your help. it was actually done in Fcp 7 (not my choice). Then encoded for the sound mix and composer. Now the director is matching it up like this in premiere and finding this problem. It’s only one file in premiere and the timecode matches fine up to this point?
  • Ben Allan
    March 12, 2015 at 3:36 am
    Is there a way to check for dropped frames? I’ve not come across it in Premiere sorry?
  • Vince Becquiot
    March 12, 2015 at 3:42 am
    You can right click on the timecode to change it from drop to non drop and see if that helps. If you drag the footage to the new sequence icon in the project panel it should create a new sequence with the correct settings.
    Vince Becquiot
  • Ben Allan
    March 12, 2015 at 3:52 am
    yup that’s how i made it.
    The dropped frames at 30fps didn’t seem to do anything either. Sorry i don’t mean to shoot down everything your suggesting, i’m trying it all out i promise 🙂
  • Tero Ahlfors
    March 12, 2015 at 4:59 am
    [Ben Allan] “The dropped frames at 30fps didn’t seem to do anything either.”
    I think it wouldn’t if your footage is 23,976. For some reason the source panel in our Premiere is showing a drop frame timecode which can be easily seen by the ;-marks in the timecode and the program panel is non-drop frame. You should probably double check your footage and sequence.
