Activity › Forums › Apple Final Cut Pro Legacy › Timecode issue when capturing through Sony JH3 – AJA IO into FCP
  • Timecode issue when capturing through Sony JH3 – AJA IO into FCP
    Posted by Simon Davies on December 30, 2010 at 5:46 am
    Hey guys,
    I’m having problems capturing some footage from a Sony Deck.
    My Setup is Sony JH3-(BNC-Composite)- AJA IO -(Firewire 9pin)-FCP. Nothing else is running via Firewire and I’m capturing 422.
    At each timecode break the deck is struggling, scanning back and forth sometimes up to 3mins to find the break.
    I have several tapes to ingest and this is slowing down the process.
    If anyone can help or point me in the right direction that would be great.
    Cheers,
    Simon
    Sam Cole replied 15 years, 9 months ago 5 Members · 4 Replies
  • Rafael Amador
    December 30, 2010 at 10:10 am
    Hi Simon,
    I’ve never worked with such a desk, but i guess that you have few control options:
    – AUTO
    -LTC
    – VITC
    – CTL
    Try the different options.
    What I CAN NOT UNDERSTAND, is why are you using the worst capturing option: COMPOSITE.
    rafael
    http://www.nagavideo.com
  • Bouke Vahl
    December 30, 2010 at 1:52 pm
    [Simon Davies] “AJA IO -(Firewire 9pin”
    and then:
    [Simon Davies] “I’m capturing 422.”
    So, are you capturing 422 video with FireWire machine control, or are you capturing with RS 422 control?
    Or, worst case, are you indeed capturing composit video while using Firewire machine control?
    If you have an AJA, use 9 pin serial control and SDI video. Firewire control is not as fast as 422 control.
    Easy to test. do NOT have a firewire cable between the deck and other equipment.
    Bouke
    https://www.videotoolshed.com/
    smart tools for video pros
  • Mark Raudonis
    December 30, 2010 at 4:45 pm
    Two to three minutes to accomplish a single cue up for capture is NOT unusual for this deck!!!
    That’s the way it is.
    Now you know why “file based, tapeless” formats were invented!
    Don’t like the long cueing times? Switch formats or try a more expensive “studio” deck. However, even the better decks do NOT significantly speed up the cueing process.
    Mark
  • Sam Cole
    December 31, 2010 at 12:37 am
    We use Sony JH3 decks with FCP and Blackmagic capture with RS422 deck control. It works perfectly, cueing up quickly and then immediately capturing frame accurate.
    If you turn your head for too long the job is done without you noticing.
    So, it is extremely do-able, and I don’t think using the Aja is any different.
    Sam Cole
    On line Mastering Facility
    FCP, Avid, Adobe
    Sydney, Australia
