Activity › Forums › Apple Final Cut Pro Legacy › Timecode Issue
  • Posted by Mike Kahn on October 20, 2008 at 8:19 pm
    A client has asked for my company to digitize HDCAM 1080 23.98 and deliver to them a 525i29.97. The problem that I have been having is that I can’t get frame accuracy. When I have the character burn in from the deck it does not match the TC in FCP. I have adjusted the capture offset and nothing helps. In fact, without changing any settings, I can go from timecode accurate on one test, to 5-7 frames off on the next. It’s maddening because it messes with the 3:2 pulldown.
    Any advice?
    I have trashed my preferences, I have made numerous device control presets with different capture offsets and nothing seems to work.
    Mike
    Mike Kahn replied 17 years, 11 months ago 2 Members · 2 Replies
  • Shane Ross
    October 20, 2008 at 8:45 pm
    What format are you capturing? 1080p 23.98 or 525i 29.97? Uncompressed HD or ProRes? Or Are you capturing HD as SD? FCP doesn’t do a frame rate conversion upon capture, but can upon output. And 23.98 is NDF and 29.97 can be DF…so there are issues there.
    Shane
  • Mike Kahn
    October 20, 2008 at 8:53 pm
    I am capturing SD, 525i29.97. The deck is doing all the down conversion for me. During the tests, I will have the 29.97 character on from the deck and will try to match that to the clip timecode and sometimes it’s on and most times it’s not.
