Activity Forums Apple Final Cut Pro Legacy Timecode in .wav files
  • Timecode in .wav files
    Posted by Mike Psenka on July 19, 2006 at 7:15 pm
    Does FCP recognize timecode embedded in an audio file? Or, do I need to convert it to a Quicktime file to show the timecode. I need to sync to smartslate and it would be helpful to see the audio files timecode. Thanks.
    Adam Driscoll replied 16 years ago 7 Members · 8 Replies
  • 8 Replies
  • Martin Baker
    July 19, 2006 at 8:19 pm
    There is no built-in way to do this on FCP as there is on Avid. AFAIK this is the only app that can access audio timecode and turn it into something usable for FCP.
    https://www.gallery.co.uk/timetools.html
    Martin
    Digital Heaven, London UK
    Unique plug-ins and tools for Apple Pro Apps
    NEW! BigTIme – resizable timecode display for FCP
  • Sean Lander
    July 19, 2006 at 10:44 pm
    sebsky tools is your answer here. Unfortunately it won’t be developed further, but I used to convert broadcast wave files (6 channels) to QuickTIme movies that I could then import and synchronise using timecode. Worked perfectly.
  • David Jones
    July 19, 2006 at 11:31 pm
    [Dave LaRonde] “That would be cool, but audio doesn’t HAVE a timecode… just a duration”
    Well, in my little world it does!
    For example… Say I’m doing location sound work on a film and want to record individual iso audio tracks for each input as well as a mix and have it locked to timecode.
    A simple laptop computer and multi-channel audio interface added to the sound cart can then record polyphonic broadcast wave files,
    which can be configured a number of ways.
    Lectro #1
    Lectro #2
    Lectro #3
    Boom #1
    Boom #2
    Timecode
    Mix L
    Mix R
    Mix Mono
    MetaData
    As someone else pointed out, https://www.dharmafilm.com/sebskytools
    https://www.one-n.com
    https://www.spherico.com/filmtools/LAFCPUG/BWF2XML/index.html
    Good Luck!
  • Michael Gissing
    July 20, 2006 at 7:27 am
    [Dave LaRonde] “but audio doesn’t HAVE a timecode..”
    Dave, both broadcast wav and SD2 files have embedded timecode. Sebsky tools (as someone else mentioned) converts them to QT with the files timecode.
  • Peter Mcauley
    July 20, 2006 at 12:48 pm
    I’ve used the BWF2XML tool from spherico.com with great sucess converting polyphonic broadcast wave files (.bwf) to quick time aif files and all the metadata and timecode comes across perfectly. Klause at Sherico provides excellent support as well.
    Peter McAuley
    Axyz Edit
    Toronto
    G5 dual 2.0
    4 gigs ram
    10.4.3
    FCP 5.04
    QT 7.03
    Kona 2 v1.1.4 with K Box
    4 X 250 gig external F800 Lacie firewire drive
    2 X 23″ Apple cinema display
  • Mike Psenka
    July 20, 2006 at 1:19 pm
    Thank you everyone for your replies. I got the Spherico trial version and it worked perfectly. Thanks again for the help.
    Best Regards,
    Mike
  • Sean Lander
    July 20, 2006 at 2:31 pm
    Glad to have helped. Be careful when using BWF it can be a bit flakey as I found out. Especially if you use the method of making alias movies.
  • Adam Driscoll
    September 8, 2010 at 6:38 pm
    @ Michael G or others,
    Is there a way to go the opposite: to export or convert a quicktime move with multiple audio channels to WAV file and carry over the timecode into the WAV file? I could export from either a quicktime movie that contains only audio channels or convert from a quicktime with video and audio channels.
    Either way my goal would be to create WAV files that have the same timecode as the quicktime
