Activity Forums Avid Media Composer timecode in source monitor
  • timecode in source monitor
    Posted by Bronwyn Lamarque on February 5, 2009 at 12:07 am
    Okay, I’m saving all my questions for today… sorry ’bout that.
    I can’t go to a specific timecode in my source monitor by typing it in from the keypad directly into the source monitor “screen.” (i.e. to find a bite). It lets me type in the timecode but when I press enter it does nothing but beep. I’m working on an Avid Newscutter on a Windows system. (By the way, is there a setting where I can turn off this beep?)
    Michael Banks replied 15 years, 4 months ago 5 Members · 5 Replies
  • Job Ter burg
    February 5, 2009 at 1:07 am
    Make sure that you have right TC counter selected above the source monitor. It should read V1. If there are two rows of timecode, make sure the top one is V1 and set to timecode.
  • Ra-ey Saleh
    February 5, 2009 at 3:51 am
    If memory serves, you have to press the Enter key NOT Return key for it to work.
  • Bill Ravens
    February 5, 2009 at 4:28 am
    huh?
  • Ra-ey Saleh
    February 5, 2009 at 4:33 am
    Whenever I’ve had the error your descibing, I”ve either not had the TC above the monitor set to the correct one (i.e. Master) – as detailed above – or I’ve pressed the normal RETURN key on the keyboard, and not the ENTER key on the Numeric keypad. Has to be the ENTER key.
    I know you said that you pressed ENTER, but a lot of people use these two keys as the same – and apart from this one instance on Avid, they are.
  • Michael Banks
    May 3, 2011 at 4:37 pm
    Thanks, Job ter Burg! That’s the info I was looknig for!
    Video Production Specialist
    MarCom Video Room
    Intuitive Surgical, Inc.
    Avid Media Composer 5 (HP Z400 Workstation: Windows 7 64-bit; Intel Xeon 6 Core W3680 CPU; 6 GB RAM); Adobe CS4; DepthQ Stereoscopic; Digital Rapids StreamZHD v.3.3.3.b47
