Activity Forums Apple Final Cut Pro Legacy TIMECODE HELP !!!
  • TIMECODE HELP !!!
    Posted by Rohan Khokar on October 30, 2006 at 9:01 am
    hi….while capturing my rushes my timecode display was not ON…….so when i play my rushes i cannot see any timecode display….now i have made a rough edit and i want to make a .MOV file with a burnt timecode on it ??? is it possible to do this ?
    Tall Jim replied 19 years, 10 months ago 3 Members · 2 Replies
  • Shane Ross
    October 30, 2006 at 9:50 am
    Video Filters>Video>Timecode Reader.
    YOu might need to nest your sequence first, otherwise the reader will read the source TC of the clips and not the timeline. Unless that is what you want.
    Shane
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Tall Jim
    October 30, 2006 at 10:39 am
    Hi Rohan
    If I understand you correctly, you want to burn the SOURCE timecode on to your movie, not the SEQUENCE time code?
    If that is the case, you need to drop a Video > Timecode Reader effect on to each one of your video clips on the time line. This will read the clip’s source timecode and display it as a burned in a superimposed box.
    If you want the SEQUENCE timecode, you need to nest your whole sequence into a new sequence (so it becomes a single flattened clip on the timeline) then appy Timecode Generator effect to the whole sequence (you can set the start timecode).
    Hope that helps
    James
