Activity Forums Apple Final Cut Pro Legacy Timecode Help FCP6 and HVX200 !
  • Timecode Help FCP6 and HVX200 !
    Posted by Brian Simon on May 20, 2009 at 4:20 pm
    Hello,
    I’m sorry if someone has asked this before but here it is,
    I just finished filming a Feature Length on the Panasonic HVX200 in NTSC 24p (not 24p advanced), standard def not HD. I shot to dv tape as back up but used a firestore FS4HD to as primary means of capture. I’ve cleared the timecode when first started filming back to all 0’s and over a two month period and several tapes, only changed the first number of the TC ONLY… when switching tapes. (example: 00:00:00:00 – 01:00:00:00 – 02:00:00:00 and so on.) That is the only change to the TC I’ve made. I never reviewed the footage until in was imported into FCP.
    My problem… when all the footage was imported to FCP6 for editing, each of the clips TC starts at 00:00:00:00. But on the tapes, Firestore and when played in the camera all show the correct ascending TC. Why am I not getting the correct TC in FCP6. I’ve tried the TCR and TCG but can’t see the TC as it was burned to the tapes. Can anyone help me out with this.
    I’m new to the HVX200 but started out using a DVX100 so I know my way around the HVX for the most part. I’ve been using FCP for over 7 years so I really do know what is happening.
    PLEASE HELP!!
    Thank for any help.
    Brian
    Rafael Amador replied 17 years, 2 months ago 2 Members · 3 Replies
  • Rafael Amador
    May 20, 2009 at 5:07 pm
    Hi Brian,
    Have a look in the Modify Menu. Timecode.
    Rafael
    http://www.nagavideo.com
  • Brian Simon
    May 21, 2009 at 4:01 pm
    Thanks Rafael, but that didn’t work any other suggestions?
    Thanks for any help.
    Brian
  • Rafael Amador
    May 22, 2009 at 10:05 am
    Hi Brian,
    Had you captured by “capture now”?
    If so this may be the reason why you haven’t got your original TC.
    rafael
