Activity Forums Apple Final Cut Pro Legacy timecode generator???
  • timecode generator???
    Posted by Zeliha Bozkurt on May 25, 2006 at 5:04 pm
    Hi
    I am doing a playout on to a VHS. I nested my sequence to be able to apply the Timecode generator filter. However when I watched the playout back there seemed to be problems like audio and video dissolves would become straight cuts randomly.
    Is there a way of getting round this problem?
    Or is there a better way of applying timecode on to the sequence.
    Zee.
    John Pale replied 20 years, 3 months ago 2 Members · 3 Replies
  • John Pale
    May 25, 2006 at 5:38 pm
    [Zeliha] “However when I watched the playout back there seemed to be problems like audio and video dissolves would become straight cuts randomly.”
    Sounds like your system is not robust enough to play this out in real time without render.
    Try reducing your video playback quality or render all your dissolves (or render everything). If you want to render everything, make sure all items are checked in the render menus (the dark green defaults to unchecked because it is full quality–no render needed unless you have problems like this)
  • Zeliha Bozkurt
    May 25, 2006 at 5:51 pm
    Thanks for the replay.
    If I check all the items in the render menu would it take much longer to render it?
    Zee.
  • John Pale
    May 25, 2006 at 6:01 pm
    [Zeliha] “would it take much longer to render it?”
    Possibly, depends on your system and the length of the timeline. Maybe not. If you render everything, you may need lots of disk space depending on the length of your project also.
    Try rendering only the dissolves and other effects first (using “render selection”). Then nest and appy the timecode filter…it may work in realtime.
    Its entirely dependent on the capablility of your system.
