Activity Forums Apple Final Cut Pro Timecode Generator, wont sync up to my timeline!!
  • Timecode Generator, wont sync up to my timeline!!
    Posted by Brandon Lanski on December 17, 2019 at 8:59 pm
    Ok, so I’m kinda freaking out right now because I don’t think I’ve run into this problem before but my timecode generator is skipping frames!
    I need to send timecode and I was hoping the client could set markers in vimeo using the review tools and then it could just be a matter of typing in the timecode but . . . what am I doing wrong here?
    Isn’t that weird?
    Andreas Kiel replied 6 years, 4 months ago 3 Members · 2 Replies
  • Jason Brown
    December 18, 2019 at 3:39 am
    I don’t know how to fix, but the colon vs semicolon is the most obvious difference. This usually indicates drop frame vs non-drop frame.
    From my basic understanding, it means that the numbers change inconsistently in drop frame to match real time up with clock time. I believe it’s 1 frame every minute except every 10 minutes when no frames are dropped…
    First google search:
    https://www.bhphotovideo.com/c/find/newsLetter/Frame-or-Non-Drop-Frame.jsp
  • Andreas Kiel
    December 18, 2019 at 2:18 pm
    [Brandon Lanski] “Isn’t that weird?”
    No ????
    It just indicates you are using Drop Frame timecode in your project.
    I’m not at a machine with FCP but I think in the effects inspector you can select a user TC instead of Source/Project, though this doesn’t make sense.
    You can switch to “Frames” – this will work with any timebase.
    Spherico
    https://www.spherico.com/filmtools
    \”He who fights with monsters should be careful lest he thereby
    become a monster. And if thou gaze long into an abyss, the abyss will
    also gaze into thee.\” – Friedrich Nietzsche, Beyond Good and Evil
