Activity › Forums › Apple Final Cut Pro › Timecode generator / reader to display source timecode?
  • John Schroter
    April 21, 2012 at 9:48 pm
    aaaaaaaah! Leo’s plug-in was working great for me prior to getting script notes back, now everything is generating timecode and I lost my link to source timecode! I broke the rule of upgrading mid-project, I know, but I did not expect this issue. This sucks.
  • Francis Mead
    September 7, 2012 at 3:40 pm
    Hey Mark
    I have a much more basic question, but also around timecode. I can’t read the original timecode on my clips in the project (this is the first major project I’ve edited in FCPX). I see you say you can “if skimmer information is turned on” – can you be more precise abouts this? – I do have skimming turned on in the timeline and I only see the timeline timecode NOT the original timecode. and btw I know there is original timecode on the clips since I was forced to make a DVD for translation purposes (of interviews in Arabic) in FCP7 – so it should be there. At the moment I’m screwed – I have several hundred clips imported – and in the event each clip only lists timecode from 00 at beginning of each clip to its duration ie NOT the original code.
    any quick help on this much appreciated!
    thanks
    Francis
  • Tim Seelinger
    September 8, 2012 at 2:52 pm
    Francis,
    I am in the exact same boat. Any suggestions from anyone would be appreciated.
    Tim
  • Francis Mead
    September 8, 2012 at 4:46 pm
    Tim – I’ve got the answers – it’s a bit long – but I’m pasting in the solution I came up with – plus a further post by someone else filling in on the new Canon Mark 111 – hope this helps! It worked for me.
    OK Tom – I’ve cracked it – a learning curve and I share this so
    hopefully it help other people in this situation. Yes, you wont’ see
    timecode in the mov. file. but – the reality is in a grey area in the
    middle so to speak. Canon developed a plug-in for FCP7 which found the
    time of day data from the two files which come out of the Canon 5d –
    the mov and the thm files – and applied it to the clips once they open
    in FCP7. This does NOT exist for FCPX. What you have to do is buy
    Grinder from Magic Bullet – about $50. This effectively does the same as
    the Canon plug-in for FCP7 – it finds the time of day data from the mov
    and thm files and adds it (you could also choose continuous timecode if
    you want – but since I’d already used time of day for my reference point
    for the translations I had to stick with that.) The way I did it, after
    reading another post, was to add the time of day code through Grinder
    (not converting the files in any other way), and then importing into
    FCPX – and then, yippee!, I can see the original time of day time code
    in the clips in the event browser – thus enabling me to find the
    segments with timecode that I’ve chosen from the Arabic translations.
    Now when I look in the event browser – I see the clips I originally
    imported, without time of day code, and above each of these a new clip,
    suffixed “main” with the timecode. Phew!! It’s all a learning curve,
    but I’m frankly surprised this hasn’t come up more often. The thread
    that finally cracked it was at Creative Cow – here:
    https://forums.creativecow.net/thread/344/656
    Thanks Tom for your comments – yes, the truth lay somewhere in the
    middle, shrouded in mystery -but this is a relatively painless
    work-around for FCPX – though Apple should be aware of it and signal it
    in my opinion.
    This was a further post someone added:
    Posted by : Seanus
    URL :
    https://www.fcp.co/forum/4-final-cut-pro-x-fcpx/6070-clip-timecode-in-project?limit=20&start=40#13842
    Message :
    Canon have fixed this issue with there new cameras. Sadly the good ol 5D
    Mk II has not been changed. Nor has Canon created a plugin that worked
    like the brilliant EOS E1 plugin for FCP X.
    Only solution is to user Grinder, QtChanger or upgrade to the 5D Mk III.
  • John Cole
    September 23, 2012 at 11:42 pm
    This solution says it works for .mov’s from cannon cams.
    Will it work on panasonic .mxf or prores 442 files?
    John
Page 2 of 2
