Activity › Forums › Apple Final Cut Pro Legacy › Timecode generator
Timecode generator
Posted by Jim Edds on February 24, 2011 at 7:49 pmI applied the timecode generator to a 1 hour clip. Works great. However, if I edit that clip with cuts then the timecode resets at the breaks. Any way to get continuous timecode for the duration?
Thanks!MBP I7 2.66, 8GB RAM, 120GB SSD, FCS 3, OS 10.6.4, 27in Apple Cinema display, G-Raid 4TB Raid 0, Sonnet Tempo Express Card
ExtremeStorms.com
Jim Edds replied 15 years, 7 months ago 3 Members · 6 Replies -
Jim Edds
February 24, 2011 at 8:56 pmThank you very much. I tried the timecode viewer and it works better but as you cut clips up after applying it – it still does not match the “timecode viewer” the actual time count of the edit. What is your workflow?
ExtremeStorms.com
Rafael Amador
February 25, 2011 at 2:09 am -
Jim Edds
February 25, 2011 at 3:09 amThanks for your input Rafael. Here’s what I’m doing.
1) put 60 min. clip on timeline
2) go to 30 min. mark and cut out, just for example everything between 30 min. and 35 min. (5 min. of video) with the razor/ripple delete
3) The TC reader generated timecode reads 35:00 now while the timecode viewer reads 30:00. Why is that?Thanks.
ExtremeStorms.com
Rafael Amador
February 25, 2011 at 3:32 amOK.
Make all your cuts, then “nest” the sequence and apply the “TC GENERATOR”.
You will get a continuous TC that should match the sequence (no footage) TC, so should match the TC Viewer too.
rafael -
Jim Edds
February 25, 2011 at 3:47 amPerfect! Que tenga un buen Noches!
ExtremeStorms.com
