Activity › Forums › Adobe After Effects › Timecode Generator
Timecode Generator
Posted by Patrick Oneill on February 19, 2016 at 7:51 pmAE displays the timecode in SMPTE which HH:MM:SS:FF, with FF representing frames.
Is there a way to have show decimal seconds instead of frame numbers?
For example: 3.233 instead of 00:00:03:07
Thanks.
Patrick Oneill replied 10 years, 6 months ago 2 Members · 4 Replies -
Kalleheikki Kannisto
February 21, 2016 at 8:42 amIt will be vaguely similar to that if you set the time source to custom and time units to 100. The last two digits will be the decimal seconds, and the rest will be full seconds.
Patrick Oneill
February 22, 2016 at 3:30 amYeah, I ended up that exact thing. It appears that the maximum fps you can set your comp to is 99 fps (rather than an even 100) so it is slightly off but that was close enough for my purposes.
Thanks for responding. Good workaround suggestion.
February 22, 2016 at 7:44 amYou don’t need to change the comp fps, just the timecode generator setting.
For instance, at 25 fps, it displays 0, 4, 8, 12, etc. for percentages of second.
Patrick Oneill
February 22, 2016 at 2:54 pmAh, nice. I was not aware that you could override the time units this way. I usually just drop in a timecode overlay in Media Encoder and changing the time units doesn’t appear to be an option in that location.
Appreciate the help.
