Activity › Forums › AJA Video Systems › Timecode from FCP to M2000
Posted by Mark Richford on May 25, 2007 at 4:04 pmNow you see it -now you don’t-
what is the secret to getting timecode from FCP running on G5 w/Kona LHe to Sony M 2000?
I have succesfully recorded the timecode from the FCP timeline to tape in the past and now it refuses. Have tried “Print to Video” / running HDSDI in Freerun as we have no master sync, Has anyone had this experience???
Mark 🙂Michael Alberts replied 19 years, 3 months ago 4 Members · 6 Replies -
Gary Adcock
May 25, 2007 at 4:13 pm[Mark Richford] ” have succesfully recorded the timecode from the FCP timeline to tape in the past and now it refuses. Have tried “Print to Video” / running HDSDI in Freerun as we have no master sync, Has anyone had this experience”
FCP does not see TC over HDSDI, only over 9pin serial.
how do you control the deck?
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows -
Mark Richford
May 25, 2007 at 4:25 pmcontrol w/ 9 pin–usually have bars/tone/slate on timeline and start first frame of video at 01:00;00:00 and usually just punch and go (assemble) GET SPEED AND HIT GO ON THE TIMELINE. and hit caps lock a lot 🙂
Frederic Lumiere
May 25, 2007 at 5:24 pmCouple things to check:
– Deck should have TC set to EXT
– Edit to tape window should have TC selected (yellow on)F
Michael Alberts
May 25, 2007 at 6:19 pmWhy aren’t you using Edit To Tape? Print to Tape is for crash recording. With ETT you have precise control over your in-point.
Michael Alberts
Ambidextrous Productions, Inc. -
Mark Richford
May 25, 2007 at 7:14 pmLooks like the answer is in the colon. When setting the timecode offset in the Kona LHe timecode window, one MUST enter the colons between the hour/minutes/secs/frms. This thing has driven me nutz! Thanks to both the first responders who helped me feel that I was not alone out here in the middle of the Pacific. Mucho Mahalos!
Michael Alberts
May 25, 2007 at 7:24 pmIf you open the ETT window and select the Black and Code button, FCP will format the tape with the proper code. Then when you punch in a beginning ouput timecode, FCP will recognize the t.c. type (DF or NDF). No futzing around manually with the colon or semi-colon.
Michael Alberts
