Activity Forums Adobe Premiere Pro Timecode from clip missing?
  • Timecode from clip missing?
    Posted by Stacy Rothwell on August 1, 2014 at 9:36 pm
    Hi…. using a Sony A7s camera that has actual timecode. However, I’m not seeing the timecode (set to 1:00:00:00 Rec run) in the XAVC clip in Premiere Pro CC 2014.
    I’ve checked the settings in PPro and have it set to use timecode from the clip.
    Vegas sees the timecode that was embedded.
    I’m sure it’s something I’m doing wrong. Thanks for any help!
    Edmond Leung replied 12 years, 1 month ago 2 Members · 1 Reply
  • Edmond Leung
    August 22, 2014 at 8:09 pm
    I am having a similar but different problem with the A7s timecode. I try every settings from the camera but all the clips are still starting at 00:00:00:00.
    FCPX is not seeing any timecode, Resolve is not either.
