Activity Forums DaVinci Resolve Timecode Error on Import
  • Timecode Error on Import
    Posted by William Edwards on March 21, 2013 at 7:56 pm
    Hello,
    Running into the issue of timecode extents do not match from an FCP XML. In Resolve metadata, the timecode is different than that of the QT of the source clip (QT tc seems to have actual metadata although at DF 59.94, while resolve sees tc starting at 0). Why is this, and what is it fault for not having the same metadata all the way through? And what would be the best fix for this problem with 7 different xmls?
    EDIT: Files shot with Sony F3.
    William Edwards replied 13 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
