Activity › Forums › Apple Final Cut Pro Legacy › Timecode DVD from P2 footage workflow
  • Timecode DVD from P2 footage workflow
    Posted by Fargoross on February 21, 2007 at 4:25 pm
    Hello,
    I’m trying to find the fastest way possible to create a timecode-dvd for our client from 2 hours of footage.
    All workflow i’m trying right now seem to take too long
    I’m editing on a G5 QUAD with FCP 5.12, OS 10.4, and 6 gigs of RAM. The footage is DVCPro 50, and my sequence settings are for DVCPro 50 as well. I have applied a ‘Timecode Reader’ filter to the entire sequence, and i do not get a render bar.
    The hard part is getting this to DVD quickly. Compressor wants to take 3 hours to do it’s “Fastest Compression”. So I figured I would just export a quicktime reference file and burn that in toast or dvdsp, as i have found either of those do a good ‘quick and dirty’ compression.
    But even the export of the reference file says it will take “At least two hours”. That doesn’t seem right, shouldn’t that only take like 20-30 minutes for 2 hours of DVCPro 50 footage? I’ve made sure to have the “Make Movie Self-Contained” button unchecked. And all the settings are set to “Current Settings”.
    Is there something i’m not seeing? Or is this just the way it is, and i’m just hoping that the G5quad would do this much faster.. Does the quicktime reference need to render the timecode filter? Is there a better way to get a timecode reader on this P2 footage to DVD?
    Thank you for your time and help,
    Sincerely,
    Ross A. Hendrickson
    Video Arts Studios
    Fargoross replied 19 years, 7 months ago 6 Members · 7 Replies
  • 7 Replies
  • John
    February 21, 2007 at 4:46 pm
    2hrs of DVCProHD50 is a not of data. Your G5 is having to decompress the DVCPro then encode to mpeg2 which is very processor intensive due to the its temporal encoding scheme. Just moving around that data is going to take time, let alone processing it. So.. it doesn’t sound all that unrealistic given that everything is being done in software.
    If all you want is a quick and dirty DVD with TC, why not get a cheap (i.e. $199) DVD recorder from Costco or Sams and run the composite signal (or component if possible) from your deck/Kona card to the DVD recorder. Then, as long as FCP can output your DVCProHD50 footage (with the TC filter applied) in realtime, all you have to do is play in the timeline and record on the DVD recorder. The DVD recorder gives you a cheap, hardware-based mpeg2 encoder which allows you to off-load that processing from your G5. If you really care about the mpeg2 quality, you could buy a much more expensive hardware-based mpeg encoder to do high-quality, real time compression.
    John Christensen
    cdesign@airmail.net
  • Eric Peterson
    February 21, 2007 at 4:47 pm
    Even if you had a hardware encoder it would take two hours. Compressor says 1.5x, pretty good. Have you tried adjusting your compressor settings to CBR of 5.0 and see if that helps.
  • Jeremy Garchow
    February 21, 2007 at 4:59 pm
    That’s because the TCR reader filter has to be rendered before you can export it. The down and dirty way to do this is to use the ‘export to compressor’ out of the timeline and not render or export the footage first. No matter what, it’s going to take some time because every frame of that timeline needs to be rendered and compressed with timecode.
    Another way to do this is to play your timeline out to a DVD Recorder in real time. You can get a cheap one for $200 or less.
    Jeremy
  • Fargoross
    February 21, 2007 at 5:14 pm
    Thanks for the good input!
    What did end up doing now is sending a composite out to a set-top DVD burner, the timeline is playing fine without any render. We still have about three more of these two hour chunks to go through.
    So if it is intensive for the processor to decode DVC Pro then re-encode it, my thought would then be to have Final Cut Pro convert the DVCPro 50 files from the P2 card directly to Uncompressed 8-bit SD.
    In the end, we want to edit in uncompressed anyways.
    Maybe this question is better off in the P2 forum, but can I set FCP to convert/import the DVCPro 50 footage as Uncompressed 8-bit?
    or would i have to import the DVCPro 50 and then render out on a Uncompressed 8-bit timeline which would seem to be much more of a hassel, as the initial ‘captured quicktimes’ would still be in DVCpro 50.. and I would be editing with one giant rendered clip.. as i would like to have the individual clips that the P2 provided.
    Thanks again,
    Ross A. Hendrickson
    Video Arts Studios
  • David Roth weiss
    February 21, 2007 at 5:17 pm
    [FargoRoss] “But even the export of the reference file says it will take “At least two hours”. That doesn’t seem right, shouldn’t that only take like 20-30 minutes for 2 hours of DVCPro 50 footage? I’ve made sure to have the “Make Movie Self-Contained” button unchecked. And all the settings are set to “Current Settings”.”
    Have you actually tried the full export? The time estimate is usually wrong, in fact very wrong. Do the export and time it, I think you’ll be pleasantly surprised. On my G5 I can turn out an export of a 86-minute 10-bit uncompressd timeline with timecode in under an hour.
    DRW
  • Bret Williams
    February 21, 2007 at 8:04 pm
    [FargoRoss] “So if it is intensive for the processor to decode DVC Pro then re-encode it, my thought would then be to have Final Cut Pro convert the DVCPro 50 files from the P2 card directly to Uncompressed 8-bit SD.
    In the end, we want to edit in uncompressed anyways.”
    I don’t think it’s very intensive. Heck, it can decompress it, add the TC reader, then recompress it in real time to send it out as you’re doing. But just copying the file to another file would take 20 minutes or so. AND you do have to compress it to one single DVCProHD file either to export via compressor or to export a reference movie. A reference movie can only reference video files on the drive. Not real time effects.
    I’ve found that exporting a reference movie, THEN opening compressor is much quicker. Or the same goes with iDVD, DVDSP, or Toast.
  • Fargoross
    February 27, 2007 at 8:31 pm
    After the slight panic last week with the timecode DVD’s, I got right on top of it this time around.
    I applied the timecode reader filter to the FCP Sequence, and sent it directly to compressor, I first applied the “Fastest Encode 150 min” setting to the clip, then i adjusted the max bit rate down to 5mbps, and the average down to 3mbps.
    These settings allowed the encode to go faster than real-time. (2 hours for 2 1/2 hours of footage). then the remaining 1/2 hour to format the disc made the whole experience ‘real time’.
    This is actually kind of a hassell with p2. Because normally I would just use our mini-dv or beta deck, and send that to a DVD recorder, which leaves my edit system free. But doing this ties up my edit system for two hours. (So i took a long lunch.. give and take i guess 🙂
    -Ross
