Activity › Forums › Apple Final Cut Pro Legacy › Timecode DVD from flipped footage
Posted by Logan Kelsey on November 20, 2007 at 5:08 amI’m trying to create a DVD with (source) timecode using footage that was shot with the Brevin lens. After flipping my content (180) when I use the timecode reader filter in FCP the TC display also gets flipped.
BTW – when I export from the viewer my timecode starts with the timeline timecode (I’ve tried re-importing and using the timecode reader in compressor as well)?? Clearly I’m missing something…
Any tips?
TIA
Cheers,
Logan
https://www.verticalonline.comJeremy Garchow replied 18 years, 10 months ago 5 Members · 11 Replies -
David Roth weiss
November 20, 2007 at 5:15 amThat’s life… You’re not missing a thing, I just tried it myself. Sorry!!!
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY™
A forum host of Creative COW’s Business & Marketing, and Indie Film & Documentary forums.
Shane Ross
November 20, 2007 at 5:24 am[Logan Kelsey] “I’m trying to create a DVD with (source) timecode using footage that was shot with the Brevin lens. After flipping my content (180) when I use the timecode reader filter in FCP the TC display also gets flipped.”
Wow…yup, like David, I just did it and yeah, there is no way to flip the TC. Well, that isn’t something Apple anticipated….the need to do that. I can see how they missed that…who would anticipate that need? Good thing to ask for now though…the ability to flip the TC.
[Logan Kelsey] “BTW – when I export from the viewer my timecode starts with the timeline timecode (I’ve tried re-importing and using the timecode reader in compressor as well)?? Clearly I’m missing something…”
Are you using the TC READER…and on the source clip? Or the TC Generator?
Shane
GETTING ORGANIZED WITH FINAL CUT PRO DVD now for sale!
http://www.lfhd.net -
Logan Kelsey
November 20, 2007 at 5:42 am[Shane Ross] “Are you using the TC READER…and on the source clip? Or the TC Generator?”
I’m using the Reader. I get the correct TC but it’s upside down (same result if I nest). The strange thing is that I thought I would be able to export the flipped content and retain the source TC. That would be slow — but I was thinking I would be able to use the (source) TC reader in compressor.
Do I lose the source TC when I render-out the 180 flip?
Cheers,
Logan
https://www.verticalonline.com -
Shane Ross
November 20, 2007 at 5:51 amAhhhh…I see what you mean. Nope, when you export the clip from FCP in any fashion, you lose the source TC.
Hmmmm….
OK…I think I have your solution. Open your files in Quicktime. Go to WINDOW>SHOW MOVIE PROPERTIES. Click on the VIDEO track. You will now see FLIP/ROTATE options. Click on the SECOND one…arrow pointing up and down. This will flip the image. Now save the clip. This modifies the SOURCE clip and thus retaining your source TC.
How about THEM apples?
Shane
Shane Ross
November 20, 2007 at 6:02 amGotta find some way to automate this…
Shane
Logan Kelsey
November 20, 2007 at 6:09 am[Shane Ross] “OK…I think I have your solution. Open your files in Quicktime. Go to WINDOW>SHOW MOVIE PROPERTIES. Click on the VIDEO track. You will now see FLIP/ROTATE options. Click on the SECOND one…arrow pointing up and down. This will flip the image. Now save the clip. This modifies the SOURCE clip and thus retaining your source TC.
How about THEM apples?”
I tried that earlier as well. When I bring those clips back (flipped in QT) in FCP those clips are still upside down.
Best,
Logan -
Jeremy Garchow
November 20, 2007 at 6:14 amI have a another way, but it involves going back a step.
Use the Perspective > Rotate filter on your UNflipped footage and set it to 180 degrees, then put in the tc reader clip.
Jeremy
Shane Ross
November 20, 2007 at 6:20 amCRUD…I thought I had the answer.
But, I like Jeremy’s better. This way you can apply this to ONE clip, then copy and paste to the rest. MUCH faster.
Shane
John Pale
November 20, 2007 at 6:21 amDuplicate the clip and put it unflipped on V2
Apply the TC filter, then crop around it to reveal the flipped image on V1.Export your Quicktime.
Reimport into FCP and use the modify timecode function to re-add your timecode.
Logan Kelsey
November 20, 2007 at 6:27 am[JeremyG] “I have a another way, but it involves going back a step.
Use the Perspective > Rotate filter on your UNflipped footage and set it to 180 degrees, then put in the tc reader clip. “
Jeremy – you rule. That works!
Thanks Shane and David as well. Awesome…
Cheers,
Logan
