Activity Forums Apple Final Cut Pro Legacy timecode drop outs in batch capture
  • timecode drop outs in batch capture
    Posted by Katie Cooper on June 8, 2009 at 4:02 pm
    2 of the 3 tapes for a wedding shoot have drop outs.
    I deleted the capture scratch to make room for another project. Now that I am back to working on the wedd edit, i thought it would be easy to batch capture the project clips. Big mistake!
    I keep getting the error message: batch capture encountered timecode breaks in sequence items. To protect your edits, these clips were left offline and not divided into separate clips.
    This is weird as I watch FCP find the in and out points and capture the entire clip. When it gets just to the end of the clip i get the error message and nothing gets actually captured.
    I tried changing the pre-roll amount to smaller number, no luck.
    I tried capturing just the clip length in the sequence timeline, FCP still tries to capture entire master clip.
    I tried changing the preferences and unchecked “abort ETT/PTV on dropped frames” as well as “abort capture on dropped frames”
    is there anything else i can do to force it to capture through timecode drop outs?
    I hope there is another option without having to recapture then manually putting clips back into the timeline 🙁
    https://www.katiecooper.ca
    Katie Cooper replied 17 years, 3 months ago 2 Members · 2 Replies
  • David Bogie
    June 8, 2009 at 5:37 pm
    First, try winding and rewinding the tape all the way through. This is an old trick from the 3/4″ and Beta days, loosens up the tape pack.
    Then, use FCP to either:
    1. Set to Uncontrolled Device and caputre the whole tape (requires supervision)
    2. or use Capture Now and supervise the capture.
    Or, you could make a dub of the tape to a fresh cassette.
    bogiesan
  • Katie Cooper
    June 8, 2009 at 11:00 pm
    thanks I will try the rewinding and stretching the tape trick next time.
    i lost my patience and just re-captured the clips and then “reconnect media” to the source clips in the edited sequence
    urghh what a headache
    http://www.katiecooper.ca
