Activity › Forums › Audio › Timecode Distribution
  • Timecode Distribution
    Posted by Paul Rozon on February 2, 2012 at 7:01 pm
    I need to have matching timecode on multiple cameras and iso decks. We have an audio mobile truck coming in (pro toools rig)who will be generating the LTC from Telcom Research – T5010. This unit outputs ballanced XLR. All my video gears TC inputs are BNC connectors.
    What kind of DA do I require in order to feed all my cams and decks from this single XLR ballanced line?
    Any input would be appreciated.
    Daniel De homont replied 14 years, 7 months ago 2 Members · 1 Reply
  • Daniel De homont
    February 8, 2012 at 3:26 pm
    According to this document:
    https://diallers.com/timecode/5010%20Schematics.pdf
    Time Code Outputs:
    Each of the two time code outputs will drive a balanced
    600 ohm line, providing a nominal level of +11 dBm.
    Each output also may be used as 2 unbalanced outputs,
    in which case they should be terminated with a 300 ohm
    resistor to ground. It is not necessary to terminate
    unused output pins. The required mating connectors
    are Switchcraft A3F or equivalent. Pin 1 is ground and
    the signal is on pins 2 and 3.
    So, how much are “multiple” cameras/iso decks?
    According to the above you could feed 4 devices/daisy chains.
    Can the cameras loop the timecode signal through?
    But probably, to remain wireless, you either sync all one in a while, or go for an ambient clockit system.
