Activity Forums Apple Final Cut Pro Legacy Timecode Display with Panasonic AG-DV2000?
  • Timecode Display with Panasonic AG-DV2000?
    Posted by Anne Leaf on April 5, 2005 at 2:00 pm
    Hi-
    Does anyone know how to get the timecode to display on the monitor when using the Pannasonic DV2000? I’m working with a mini dv tape and going out with RCA. Any help would be greatly appreciated.
    Anne
    Anne Leaf replied 21 years, 5 months ago 2 Members · 4 Replies
  • Thaxter Clavemarlton
    April 5, 2005 at 2:49 pm
    On larger Sony decks there is an switch on the front (or a choice in a menu) that allows you to display the “Characters” over the video.
    On smaller Sony decks and camcorders this menu choice is called “Display”.
    Don’t know if Panasonic has these choices, but I would think they would be similar.
  • Anne Leaf
    April 5, 2005 at 3:10 pm
    Thanks so much for your reply. There is no character button that I can find. There is a display button, but it only changes the display on the deck, not on the monitor. There is also a button which will display the tapes date and time on the monitor, which leads me to believe there must be a way to display the timecode…
    April 5, 2005 at 4:49 pm
    Page 19 of the AG-DV2000 manual says to use the remote control to set this:
    OSD Mode (On Screen Display)
    1. Press MENU, and then select PTION SETUP 1
    2. Select OSD MODE
    3. Select “ON”
    4. Press MENU twice to exit the OSD
    This should give you a “bunch” of on-screen info, one line of which is your TIMECODE reader.
    On consumer decks like these you will usually have to accept that a lot of info will need to be on the screen along with the TC.
    BTW, like for so many items, I simply downloaded the complete User Manual in PDF by finding your deck on Amazon.com and clicking the download choice.
  • Anne Leaf
    April 5, 2005 at 5:21 pm
    Thank you so much!
    I googled for the manual but couldn’t find it. I’ll use amazon in the future.
    -anne
