Activity › Forums › Apple Final Cut Pro Legacy › Timecode Display In Final Cut 7 Capture Tool
Posted by Alvin Lowery on May 11, 2010 at 2:55 amHow Do You Display The Timecode Display In Final Cut 7 Capture Tool?
Doug Beal replied 16 years, 4 months ago 5 Members · 4 Replies -
Shane Ross
May 11, 2010 at 3:42 amYou don’t. The new timecode window only works with the Canvas and Viewer.
Shane
Read my blog, Little Frog in High Def -
Michael Alberts
May 11, 2010 at 5:29 pmNor does the timecode display work during Edit To Tape, something we’ve been asking for since FCP v1. In addition, your audio meters don’t work during capture or Edit To Tape.
Michael Alberts
Ambidextrous Productions, Inc.
http://www.ambidextrous.net -
John Heagy
May 11, 2010 at 10:29 pmIf you’re capturing HD via a Kona card you can see the running embedded TC via the AJA ControlPanel with the “Timecode” tab selected. Be sure to position the Aja ControlPanel so it’s unobstructed when FCP is capturing.
This may be doable with a Blackmagic card as well.
John Heagy
Doug Beal
May 12, 2010 at 3:43 amI patch the character out of the deck to the composite video input of my external monitor during capture or ETT. also monitor audio levels via external audio meters.
the only time it doesn’t work is in 23.98 fps material which won’t display composite.
for that it’s have a little faith or an EDL for capture, and a quick trip to the machine room during bars for ETTDoug Beal
Editor / Engineer
Rock Creative Images
Nashville TN
