Timecode Cuts?
Is there a way to make cuts by just typing in time you need cut? I have a log sheet to go by and rather then having to use razor every time I need to make a cut is there a faster method? I know “B” is the shortcut for the razor tool I was just wondering if it’s possible to do it just by typing in the numbers and have the cuts automatically happen as you do it.
Thanks in advance!
