Activity › Forums › Apple Final Cut Pro Legacy › Timecode Convert 23.98 to 25
Posted by Brandon Katcher on April 13, 2012 at 10:29 pmI am converting some video from 23.98 to 25 for PAL. Problem is, I also need to convert all the transcriptions to the PAL time codes. Is there an easy way to do this, or do I need to redo them all?
Any help is much appreciated,
BrandonBrandon Katcher replied 14 years, 5 months ago 3 Members · 5 Replies -
Michael Gissing
April 13, 2012 at 10:35 pmIf you do a frame rate conversion to 25 in Compressor (not a speed up) it will still be real time.
However, I don’t think Compressor will be able to pass the original source codes so you will manually have to set the timecodes on each new clip to match the original. Transcription timecodes will then be within one frame.
Brandon Katcher
April 13, 2012 at 11:02 pmThank you for the quick reply.
I haven’t had good luck doing a framerate conversion. I’ve always been under the impression that a speed up is a better option. But any tips on settings to do it this way? -
Michael Gissing
April 13, 2012 at 11:06 pmSpeed up will look smoother but change real time and therefore all timecodes plus pitch of the audio.
Personally I haven’t been satisfied with software frame rate conversions and prefer to sub contract that job to a facility with a Teranex or similar hi end hardware converter.
It is a topic that has been covered in more depth here so a search of this forum might help with specific settings in Compressor or alternate software.
Juan Salvo
April 14, 2012 at 6:30 amThere are several apps for dealing with srt or caption files that will convert the frame rate of those files by basically counting frames and then converting that to time effectively simulating the speed up. What format are your transcriptions in?
online editor | colorist | VFX | BD author
Brandon Katcher
April 14, 2012 at 3:19 pmThank you for the reply. Currently, I’m using a program called inscribe for the transcriptions, but I can export to plain text, XML, HTML, Final Cut Pro markers, sub rip and spruce.
Brandon
