Timecode & Clip Question
Hi
I’m not sure I understand something. I recently shot some footage that lasted around 45 min. But at the 15 minute mark of this music show, I had to disconnect the 110 power, connect a battery and take the camera outside to listen to what I had just taped – for a possible sound issue. When I plugged everything back in, all went as normal.
Now when I got back to the studio and started the log and capture, it too went normal. After I finished the 45 min log and capture procedure, I put the captured clip into the viewer to watch it. Everything was fine, but the clip stops where the camera stopped. It seemed as if there was 30 minutes missing.
But I went to my scratch folded and the clip is there in it’s entirety. I don’t recall this ever happening? If there is a timecode break, doesn’t it continue the capture anyway? That’s the way it looked when I was capturing the tape. I have the preference set to ignore timecode breaks too.
At this point, all the footage is there in the scratch folder. But only 15 minutes of it shows up in the browser. How do I get the rest of the 30 min clip in the browser? I wouldn’t drag it out of the capture scratch folder and put in the browser would I? It would then be missing from the capture scratch folder.
Can the media manager fix this?Thanks for any help!
Jonny Cates
