Activity Forums Adobe After Effects Timecode burn in window using the Numbers Effect
  • Timecode burn in window using the Numbers Effect
    Posted by Michael Tapp on April 20, 2008 at 3:01 am
    Hey Guys-
    I can’t say it enough, Creative Cow is a phenomenal resource. You guys have bailed me out more than a few times in the past. I need to add a timecode window to a video file(quicktime reference). The timecode effect has a lot of negative space below the numbers that is distracting.
    The work around I found was the Numbers effect. I made the black window box with a mask and a black solid behind the video. With the Numbers effect I couldn’t find a way to start the timecode at 01:00:00:00 . The ‘timecode’ with the numbers plugin would also slightly move. I don’t understand the movement, I checked and there were no keyframes on that layer. I know there is probably a bonehead simple solution to start the timecode @ 01:00:00:00. Any help will be appreciated and thank you for your time.
    Serge Hamad replied 18 years, 5 months ago 2 Members · 3 Replies
