Activity Forums Square Box CatDV Timecode burn in export
  • Timecode burn in export
    Posted by Nigel Gourley on February 12, 2014 at 6:02 pm
    We want to do exports of clips with a timecode burn in. However in the drop down boxes for selecting what gets burnt in there is DV TC and MXF timecode but nothing for QT timecode and these are QT movies with timecode in them. How do we get to see this timecode. There doesn’t actually seem to be a column anywhere for QT timecode.
    The source files are Prorez Qt
    Any hints?
    Dougal Matthews replied 12 years, 7 months ago 2 Members · 1 Reply
  • Dougal Matthews
    February 18, 2014 at 3:23 pm
    hi
    to burn in timecode one just needs to tick the “add timecode track” box see red box in screenshot below
    the fixed text in the burn in text selection is for you to add additional metadata in the screenshot below
    In this instance i’ve already added clip name ( green box ) and am appending aspect ratio ( yellow box) so i’ll get an overlay with something like “My Clip Name 16:9” burnt in as well as the timecode
    You can add in quite a lot of info limited mainly by the amount of screen space you have
    you can also add a watermark by choosing a graphic such as a company logo or “internal use only”
    Improvise Adapt and Overcome
