Activity Forums Adobe Premiere Pro Timecode Burn-In
  • Timecode Burn-In
    Posted by Peter Slabysz on January 5, 2023 at 9:28 pm
    So I figured out how to use Export to create a TC window burn with a Source name. However, the project has a bunch of folders and if all the clips get strung together into a Sequence, the Source name takes on the SEQ name. Any way to get the original source name to show up? I also have access to Media Encoder.
    If you have suggestions, please overexplain. I don’t use PP much.
    Peter Slabysz replied 3 years, 8 months ago 2 Members · 2 Replies
  • Eric Santiago
    January 6, 2023 at 3:23 am
    Do you need each clip to have the burn?
    For that I use AME.
  • Peter Slabysz
    January 6, 2023 at 4:42 pm
    Hi Eric,
    Yes, I have clips from half a dozen shoots that need the burn-in. So in Encoder, will I just drop the folders in with multiple clips and metadata without having to drill into each media file?
